Author Topic: Rear bulbs  (Read 4115 times)
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
Rear bulbs
« on: 07 October 2016, 12:53:42 »
I dont currantly have my mig to hand but looking on hellfrauds site and autobulbs they seem to show different bulbs for the rear and haynes is no help
Can I have a list of the bulb sizes
Indicator
Side
Stop/ tail
Reverse
Fog
Cheers
« Last Edit: 07 October 2016, 13:01:52 by frostbite »
e46 325i se - 1.8vvti avensis liftback
frostbite
    • 00' e46 325i se
Re: Rear bulbs
« Reply #2 on: 07 October 2016, 23:46:56 »
That cant be right
There should only be for one cluster a tail, tail/ brake, fog, reverse and indicator
That post says there are 2 brake and 2 tail
dave-b
  • Wigan, Lancs.
    • Elite 3.0 F/L
Re: Rear bulbs
« Reply #3 on: 08 October 2016, 03:03:12 »
From memory, PFL saloons have two tail light bulbs per side, a 380 5/21W and a 207 5W while FL cars have only one, a 380 5/21W.
Re: Rear bulbs
« Reply #4 on: 08 October 2016, 09:57:28 »
Pre FL have 2 tails per side, in same cluster.
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
Re: Rear bulbs
« Reply #5 on: 08 October 2016, 18:55:00 »
Yep - My MFL a few years ago chirped up on the Central Display 'Tail Light'.  I looked at the back and thought it was pulling my leg as looked fine  ::)  ON closer inspection, and bulb removal yes one of the pair of tail lights in the outer cluster had gone  :D
My first (and only so far  :D) bulb failure with the old girl in the 16 years I have had her  :y
frostbite
    • 00' e46 325i se
Re: Rear bulbs
« Reply #6 on: 11 October 2016, 12:51:41 »
Sorted
It has
Fog p21w
Reverse p21w
Tail  r5w
Indicator py21w
Tail brake p21/5w
Now going to order leds for the rear and front indicators
Re: Rear bulbs
« Reply #7 on: 11 October 2016, 13:08:20 »
Sorted
It has
Fog p21w
Reverse p21w
Tail  r5w
Indicator py21w
Tail brake p21/5w
Same as the link I posted ???
Re: Rear bulbs
« Reply #8 on: 11 October 2016, 13:47:40 »
Estates have 21/4 Fog/Tail :y
These have double offset pins, 21/5 won't (shouldn't) physically fit...
Re: Rear bulbs
« Reply #9 on: 11 October 2016, 14:03:04 »
But obviously do when forced. Ive seen various cars over the years with one side's light s brighter than the other
Re: Rear bulbs
« Reply #10 on: 11 October 2016, 14:14:49 »
Hence the shouldn't  ;)
Re: Rear bulbs
« Reply #11 on: 11 October 2016, 17:06:12 »
Yes ..... I knew what you were getting at, but the easiest answer when on a phone.  ::)
 I can never quite get my head around how people force either the correct bulb in the wrong way around or even forcing the wrong bulb in. Someone on the Smart form had problems with his/her tail lights & he/she'd forced a single filament bulb in, instead of a twin stop/tail lamp  ??? ???
