Author Topic: Omega 2.2 CD manual 2003 Air Con problem  (Read 7204 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: Omega 2.2 CD manual 2003 Air Con problem
« Reply #15 on: 03 November 2016, 20:04:41 »
But where has the 800g of gas gone?
When was it last checked and gassed?
Last filled 4/8/10 according to a sticker. I've had the car for about 3 years and it was my sons friend who had it re-gassed in 20010.
« Reply #16 on: 03 November 2016, 20:05:43 »
100g per year can be considered 'normal' if on the high side...
Don't forget most of the aircon system is made from aluminium, so not unreasonable for a 13 year old condenser to become slightly porous ;)
Andy A
  • Bristol UK
« Reply #17 on: 03 November 2016, 20:09:48 »
Good news my local garage that I trust has just started to offer a Free Air Conditioning Check to see if the air con is running efficiently. They also offer a free nitrogen pressure test to check for leaks in the system. They charge £49 for a re-gas.
I have a couple of questions.
If the system is opened to work on will the Dryer have to be replaced with new?
If yes does it have to be a genuine one or will a third party one be OK?
I will get two VX valves before I take the car up there.
Thanks
I didn't replace the valves come the end because there was still gas in the system.
I took the car in for the free air con check and the next thing I new it came back to me already re-gassed. No printout and no nitrogen pressure test done.
I had to ask how much refrigerant was left in the system and it was about 100g. I'm sure he didn't do a pressure test because he had the same 2 pipes from one machine to the air con connected from start to Finnish.
I ask how much refrigerant did it take and he said 900g.
I've never had an air con re-gassed before. For what I have read I should have had a printout or does this depend on the garage?
Its running ice cold now.
Thanks
That's the standard 'fast fit machine' it may have done a vacuum test, but you wont know without the print out and you really needed a pressure test. With that much refrigerant gone it will almost certainly escape again - how  long it takes will give you an idea of where its getting out.
Steve
They did put a UV dye in it and said being that I am concerned about it I could go back in a couple of weeks and they will put an UV light on it to see if it has leaked.
Andy A
  • Bristol UK
« Reply #18 on: 03 November 2016, 20:13:55 »
Would that still show up with a UV light.
« Reply #19 on: 03 November 2016, 21:31:49 »
Yes if there's dye in it ;)
« Reply #20 on: 04 November 2016, 12:16:24 »
No as the dye is generally to large a molecule to get through any porosity
« Reply #21 on: 04 November 2016, 12:20:24 »
Yes if there's dye in it ;) Apparently not then :-\
Andy A
  • Bristol UK
« Reply #22 on: 05 November 2016, 08:34:14 »
Would they be able to find that type of leak with a sniffer device and or a pressure test?
Thanks
