another one for the builders
Started by Gaffers, 10 October 2016, 18:31:20
Gaffers
#15
The stairs are U-shaped with the lower section built on a base.  The long section is against the supporting wall and sits on the base.  The 3rd and last section is the part I am not sure about as it partly straddles the wall in question.
Here is a drawing from the paperwork, seems to suggest non-load bearing.  The wall in question is boxed in red.
And plans for the stairs, which I cannot figure out....:
I would agree at non load bearing, the floor joists in this case will run left to right and pickup on a load bearing walls either side of the house.
Just stick a few holes above the door in question with a small screwdriver and check for the presence of wood only.
Gaffers
Thanks, shall do :y
Would a joist/metal detector do or should I physically check.
I would check, even a screwdriver of say 4mm diameter will allow you to prod and determine what's behind the plaster work and any holes are easily filled being so small.
Gaffers
Mr Gav
It may be partially load bearing as most modern houses don`t have internal block walls anymore, and it`s unlikely to have any steel work as this is also uncommon in modern housing due to costs.
The only sure way to tell is if you could get a hold of the drawings for the floor joists, other than that you can see which way the joists run, if they`re parallel with your wall then you should be fine but I`d make sure that both kitchen and living room joist run parallel with the wall.
Quote from: Mr Gav on 12 October 2016, 12:57:30
Ermmm....no, Gav. There's another way to find out for sure.  ;D
Its not load bearing, absolutely clear from the drawings and dead easy to check.
Internally they use concrete for load bearing walls up to circa 1.5m then its steel (as a concrete lintel gets a bit deep above that sort of span)
Mr Gav
Thats what happens when you don`t read the post in it`s entirety  ;D
Never saw the bit with the drawings on lol
Mr Gav
Quote from: Marks DTM Calib on 12 October 2016, 13:36:02
You wouldn`t find one of those on a stud wall though would you?
Quote from: Mr Gav on 12 October 2016, 14:42:33
You wont find a load bearing stud wall with a double door in though  :y
Gaffers
Quote from: Mr Gav on 12 October 2016, 14:35:51
Yeah, erm you're never working on my house.....ever  ;D ;D
Mr Gav
Quote from: Guffer on 12 October 2016, 16:31:37
Too far for me anyway  :P ;D
