Author Topic: Loss of Electrics  (Read 2352 times)
rkwooderson
  • Gosport
    • 2001 Omega 2.6 CDX
Loss of Electrics
« on: 14 October 2016, 21:17:01 »
I have a problem with Central Locking on my 2001 Omega 2.6. I was checking the fuse box to see if there was any problem there , when all electrics failed.  No lights, no radio, no ignition lights nothing.  Any attempt to use anything resulted in an intermittent beeping.
Have I inadvertently shorted something. Any ideas on how to proceed.  No problems with car had previously been seen.
flyer 0712
Re: Loss of Electrics
« Reply #1 on: 14 October 2016, 21:44:51 »
possibly the continual beeping is the sounder going off ....this is situated under the wiper grille/cover on the drivers side under the bonnett....these can be a problem with leaking batteries in the unit,,,,this can lead to the unit catching fire...so you may be wise to check this unit ... :y
rkwooderson
  • Gosport
« Reply #2 on: 15 October 2016, 07:22:03 »
Doesn't sound like the power sounder.  Is there any component on the internal fuseboard which could cause total power loss. A connector, relay or fuse.  Feels as though something has just pulled the plug out.
  • Auckland
    • Mazda MPV
« Reply #3 on: 15 October 2016, 09:41:36 »
More likely to be a broken crimp on one of the big wires to the battery or a broken (or fused) fuse link in the fusebox on top of the battery.
powerslinky
« Reply #4 on: 15 October 2016, 12:06:01 »
If you were "in" the fuse  box under the bonnet & power went while you were doing it. .  chances are it is something you have disturbed there or around that area :-
Quick prod around with a mulitmeter may be a way forward   . . .HTH
