Author Topic: Lpg leak  (Read 4863 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Lpg leak
« on: 19 October 2016, 17:45:38 »
I've got a little LPG leak on my car but here is the funny thing, you only smell it in the cabin when the lpg tank is nearly empty  :-\
It never smells when full of even half full  :-\
Any ideas ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Lpg leak
« Reply #1 on: 19 October 2016, 18:14:15 »
Strange, end of the day a leak is a leak so will need sorting, could it be coming through the heater vents from the engine bay?
If it helps, when they do leak you tend to get a white frosted deposit build up from around the culprit / area, but that will soon disappear (melt) when the leak stops
Re: Lpg leak
« Reply #2 on: 19 October 2016, 19:49:22 »
Had similar a few years back which quickly got worse followed by the engine refusing to run on LPG... so it went to a local specialist PDQ ...
In my case the internal pickup pipe had corroded such that when the level dropped to less than 1/3rd the pickup was collecting gas not liquid, seems this affects the way the vaporiser/injectors cope and leads to a smell of unburnt LPG in the engine compartment which drifts into the cabin, followed by a drop in pressure such that it won't run on LPG. Stand for 10 minutes the pressure builds back up and it runs for 5 minutes before the cycle repeats.
Solution is either have enough LPG in the tank to cover the hole, or, as I did, fit a new tank !!.
Apparently the pickup pipe is thin stainless steel, all it needs is a scratch during manufacture to allow corrosion to set in as it is stainless NOT "corrode-less" and steel corrodes quickly in contact with LPG.
Probably all wrong but that is what I was told, new tank did however sort the problem out  :)  Might not be your problem .. but worth mentioning .. :)
Re: Lpg leak
« Reply #3 on: 19 October 2016, 19:54:24 »
Surely it needed new valve set, not tank?
Re: Lpg leak
« Reply #4 on: 19 October 2016, 20:10:26 »
According to LPG place the internal pickup pipe is not replaceable, and given the amount of red metallic crud that came out of the filter I went along !!
They "might" have done me .. but the tank was 6 years into its 10 year life anyway .. so a new tank wasn't that bad an idea IMHO ....saves worrying about changing the tank later anyway ..
Re: Lpg leak
« Reply #5 on: 19 October 2016, 22:21:43 »
IIRC the 4 hole tank has the pickup fixed during manufacture :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Lpg leak
« Reply #6 on: 19 October 2016, 22:23:45 »
That lot rings a few bells Nige sadly but one thing that I can't quite get my head around  :-\
The LPG setup has 2 12volt solenoid valves on the system.
1 on the tank and one on the KME Gold reducer.
Plus the 6 injectors which also should be closed.
With no volts at either solenoid, my understanding is that these 2 should isolate the LPG at both the tank end and the reducer end.
Is it a case that they will stop lpg liquid under nominal pressure but not gas vapour ?
I have noticed that if I park my car up with say 1 green light on the controller for a few days then go back to it, you can bet your life whether I can smell gas or not that the red light will be on when the engine is started  :-\
Also I know these systems tend to hunt around a little when its dragging the last few miles worth upto the engine but in the last 6 months or so, its been much worse  :-\
Might not be connected but about 4 years ago, with a full tank of lpg and on a very hot day, the pressure relief valve blew causing one of the loudest bangs i've ever heard.
Could this be connected ?
Also when the kit was fitted to my old pfl, one of the injector wires did get welded to the exhaust manifold after a cable escaped the loom after some maintenance work.
It has caused injector faults in the past due to possibly straining the injector solenoid open but I haven't had this problem for a few years  :-\
For reference, the system has been on 2 cars of mine and is getting on for 6 years old  :-\
Stargazer57N
Re: Lpg leak
« Reply #7 on: 19 October 2016, 22:27:36 »
I would say is to get the leak fixed for your own safety as LPG is highly flammable.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Lpg leak
« Reply #8 on: 19 October 2016, 22:28:39 »
That's certainly the cunning plan  ::) ;D ;D
Re: Lpg leak
« Reply #9 on: 19 October 2016, 22:41:28 »
Doesn't sound quite like my problem then .. I never actually had "leak" as regards a "known" loss of LPG, just that when low AND RUNNING there was a slight whiff of LPG, when not running there was never any smell, that was half my problem .. I kept looking for a leak that wasn't there !!
It was when the whiff got a bit stronger and the engine started dropping back to petrol that I took it to the LPG place for advice, they were very quick to suspect this pickup pipe - known problem ?? - and went for the filter as a backup .. I watched them take it off and pour - literally - metallic red crap out of the filter onto a piece of paper !! They also said that if it hadn't of been for a decent filter I'd be buying a new vapouriser as well .. :(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Lpg leak
« Reply #10 on: 20 October 2016, 17:27:59 »
Okay Nige, thanks anyway  :)
Does sound like you had a luck escape with the red shit in the tank though  :-\
I cant get my head around how / why i've got a leak when the tank is pretty empty but not when full  :(
I'd have thought that a full tank would mean more static pressure giving me more of a chance of a leak  :-\
This is bugging me now  :(
Re: Lpg leak
« Reply #11 on: 20 October 2016, 18:57:40 »
Vapour would leak more readily than liquid as the molecules are far smaller :y
Re: Lpg leak
« Reply #12 on: 20 October 2016, 19:22:29 »
Only time I've seen a 4 hole tank with all the valves out was TBE, and I vaguely recall it was just a tank with 4 holes in.  All pickups, floats etc were part of the valve set.  Same as single hole tank....
Re: Lpg leak
« Reply #13 on: 21 October 2016, 00:28:03 »
As I fitted the valve set I'm sure the only one that had to be "fed" in was the float arm :-\
Re: Lpg leak
« Reply #14 on: 21 October 2016, 09:03:19 »
Yep, pickup pipe is built into a 4 hole tank and the valve just bolts up to the threaded bush in the tank. :y
Page created in 0.022 seconds with 20 queries.
