Airbag disabling
Started by bob.bowring, 22 October 2016, 09:29:32
Diamond Black Geezer
#15
Does anyone know if unplugging a wire to the airbags will throw up an airbag warning light(which then can't be deactivated without tech2)? Or pulling a fuse?
It's certainly not in the same level of usability as a simple switch like on most/all modern cars, but if the OP needs it as a feature it must surely be doable?
I know it's a 'you must tell your insurance company' thing etc, but that red tape issue aside for now, as far as I can see that warning light is the only real problem I can think of here - if the airbag is temporarily disconnected will the light come on 'for good'. Because a very simple switch, perhaps hidden behind the dash/vent trim panel when you open the front passenger door would be a good place. The trim pings off very easily, but you could hardly deactivate the airbag accidentally, you'd need to open the door first.
Just theorising at this point...  :y
Assuming it's the same as the side airbags (facelift) then yes, unplugging any airbag will cause the light to come on el permanente until a chat with a tech2; even once you've plugged it back in (as I found out when I accidentally turned the ignition on with the door loom disconnected)
Quote from: aaronjb on 25 October 2016, 10:03:08
Yep, and in that state, none of the airbags or pre-tensioners will work.
Simplest solution is to either fit a forward facing child seat, or put the child seats in the back...
The end :y
Quote from: Doctor Gollum on 25 October 2016, 10:35:13
Simplest solution is to either fit a forward facing child seat, or put the child seats in the back...never to go near one of those horrible little snot-bags people call children.
:-X ;D
Quote from: aaronjb on 25 October 2016, 11:00:42
:-X ;D
Has always worked for me. :y
:-X ;D
Top advice :y
ronnyd
