Author Topic: Need part numbers for a wishbone refurb  (Read 18105 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
Re: Need part numbers for a wishbone refurb
« Reply #45 on: 01 November 2016, 11:31:13 »
Mine has had poly bushes for over five years. Used the lithium grease that came with them, and haven't touched them since.
A geometry check isn't necessary if you do have to lubricate them.
Poly bushes eliminate a number of suspension issues cheaply and easily. They are a must have part
Nike I thought I had some white lithium grease in the garage. Just looked and its not white Lithium its calcium sulphonate based, Ramonol Advanced White Marine Grease.
http://www.ebay.co.uk/itm/Ramonol-Advanced-White-Marine-Grease-500g-/252169662902?hash=item3ab67bb1b6:g:2rwAAOSwEgVWRgMX
Is this a similar sort of stuff as the white Lithium grease you use and will it do the same job?
Thanks
« Reply #46 on: 01 November 2016, 11:59:27 »
Copperslip :-X
Andy A
  • Bristol UK
« Reply #47 on: 02 November 2016, 13:53:03 »
Copperslip :-X
I thought it looked like Copperslip on the photos. Yet on the Powerflex web site it says its their own formulated PTFE/Silicone bush assembly grease.
https://www.powerflex.co.uk/road-series/fitting-guides#
Looks like they might have changed it to Silicone with PTFE.
« Reply #48 on: 02 November 2016, 14:02:02 »
Possible... not bought any recently to confirm ;)
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #49 on: 02 November 2016, 15:34:45 »
It was copperslip with mine, but that was about *?£%& years ago now. I think I used red grease last time for no real reason other than I wasnt sure if 'normal grease' would corrode the poly as it does rubber. I suspect not, though. Vaseline, grease, copperslip, whatever I'm sure will be fine.  :)
« Reply #50 on: 02 November 2016, 16:51:54 »
Rubber is a natural product and therefore susceptible to chemical attack and rapid fatigue in unsuitable applications. Polyurethane, however, is about as unnatural as Angela Merkel and Jimmy Krankee having a baby... And is pretty much bombproof ;)
« Reply #51 on: 03 November 2016, 09:04:11 »
Or indeed, as unnatural as Angela Merkel, and Jimmy Krankie...  :D
Pages: 1 2 3 [4]  All   Go Up
