Engine died at Chieveley
Started by terry paget, 29 October 2016, 09:34:09
terry paget
After a week of good behaviour in local runs this car failed again on my Friday run to Oxfordshire. After a 65 mile fast run to Wantage I parked for 15 minutes, then engine refused to start. This engine  normally starts first time. After six 5 second starter squirts I paused, then gave a 20 second squirt with throttle wide open in case it was flooded; still no life. Panic was setting in. I opened the bonnet and unplugged the MAF sensor. I cranked the starter, engine started. Phew!
I preceeded to my first call, 2 hours chatting to old friend. Then drove to Culham laboratory to play table tennis. Later I drove to Cherry Tree, Steventon for a meal. Finally I drove the 70 miles home.
What is the fault. Crank sensor? Battery? Please advise.
I would be surprised if the MAF affected starting. My money's on the crank sensor.
If you are passing the Oxfordshire/Northamptonshire border, I'll happily plug the tech2 in...
Quote from: Kevin Wood on 05 November 2016, 10:15:24
I'm thinking similar...
Quote from: TheBoy on 05 November 2016, 11:24:05
All the other faffing may well have given it a chance to get its shit together...
terry paget
Thanks for advice gentlemen. I have now changed the crank sensor. Will report after next Friday.
terry paget
Happy to report that yesterday's 200 mile run, to Didcot, Wantage and Culham Laboratory, passed without incident - no stalling, failing to start, or other engine misbehaviour - so it looks like changing the crank sensor has cured things. I thank all for their advice.
Quote from: terry paget on 12 November 2016, 04:08:46
fingers crossed that's the end of the problem :y
