hydraulic handbrake setup ?
Started by madmandave, 29 October 2016, 13:27:27
madmandave
 :-[ well its plumbed in but locked without applying the wand ? Need go over it all again tomorrow with more light.
Quote from: madmandave on 30 October 2016, 13:01:20
Quote from: minifreek on 30 October 2016, 11:08:20
The 2.2 can become a powerful weapon with the correct bits bolted to it - like a supercharger....
You should at leats be able to get the rear to slide, but doubt it has the grunt to hold it in a drift....
I used to get mine to slide (V6 2.5 235BHP) on my local track, especially in the wet.... but that was with an auto and standard diff... which didnt help TBH.... was looking for a LSD but none came up at a good price....
With a manual, you should be able to get it to slide, especially with a welded diff. I wouldnt like to drive it on a normal road though....
im interested I  your supercharger idea I had thought of the saab 9000 2.3 turbo unit petty sure its the same bell housing pattern? I had 1 yonks ago stage 3 map 480bhp. Now then I would have a serious machine maybe comp spec it and enter  :) its fine to dive mate
Why not use a 2.2 Astra turbo engine? It's a simple like for like bolt in, and the only plumbing you'd have to do would be for the intercooler.
madmandave
Thats a good idea Nick thanks I take  for that id need the whole loom, ecu and transponder chip and ring ?
baggers
Quote from: madmandave on 29 October 2016, 22:21:41
Yes mate still needs to be street legal if possible I think its to heavy for a 3.5t beavertail  :'(
Because just wondering, something comes to mind for road legal you can't share the same hydraulic lines for normal braking and hand brake, they need to be totally independent .
madmandave
Quote from: baggers on 31 October 2016, 19:31:46
Not 100%  but should mot ok as long as it doesn't effect the pressure ie passes the rolling road test the one fitted can be locked in position.  ;)
Presumably for MoT purposes, the factory handbrake can be left in situ :-\
My concern would be hydraulic failure causing sudden braking loss...
Quote from: Doctor Gollum on 01 November 2016, 10:02:53
Yep, for this reason the MOT manual requires that the parking brake is:
"capable of being maintained in operation by direct mechanical action only"
madmandave
Yep still got factory hand brake  just in the process of cutting the center console I might be able to mod the heater channel to keep the rear vent
