Author Topic: Strange rear electric window fault  (Read 5756 times)
powerslinky
« on: 29 October 2016, 19:15:57 »
hi all
          Both fronts & rear n/s windows all work fine  . .
But rear o/s  behaves as follows  . .  :-\       It will open from either the  drivers switch bank or it's own rear one , stops where ever you want it to . .all good so far  :y
but it will not close from either switch until you turn the ignition off, remove key & then re insert the key & switch ignition on.  Once closed window will open  again , but will not close until the switch off/pull key out etc is carried out :-\ :-\
Any ideas where to start looking?  TIA   Al :y
Re: Strange rear electric window fault
« Reply #1 on: 29 October 2016, 19:24:19 »
It all starts with the drivers door switch, so begin there :y
You can readily swap the rear door switches to rule them out too, but rear switches are powered from the drivers door regardless...
« Reply #2 on: 29 October 2016, 19:28:59 »
Are you sure its just that one, as the schems show both sides take same feeds.
The drivers doorswitch may affect the consumer relay
powerslinky
« Reply #3 on: 29 October 2016, 19:30:55 »
Asume you mean the actual window switches ?  I have a spare drivers switch bank & a couple of rears as well. Will have a swop about tomorrow if those are what you mean.
thanks ;)
powerslinky
« Reply #4 on: 29 October 2016, 19:32:30 »
Yes Jamie,   only that one  . . all others open & close repeatedly with no problem
Bit strange eh ? :-\ :-\ :-\
Is there a window "Reset" proceedure that can be done ?  :-\
« Last Edit: 29 October 2016, 19:35:25 by Essex Big Al »
« Reply #5 on: 29 October 2016, 19:33:59 »
thanks ;)
Exactly, but swap the existing rears side to side and see if the fault moves before trying a n other switch... if no change then try the drivers switch and if still no change, it will be out with the multimeter :D
« Reply #6 on: 29 October 2016, 19:35:38 »
Also pull F1 and F35 for an hour or so, then replace. Then try again.
powerslinky
« Reply #7 on: 29 October 2016, 19:37:22 »
thanks ;)
Oh !  . . ..    :o   Auto leckys not my hot spot :P :P :P
powerslinky
« Reply #8 on: 29 October 2016, 19:39:54 »
Ok Jamie  . . . will do switch swop around first though before pulling fuses
thanks  . . :y :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 29 October 2016, 19:41:45 »
Mine's been the same for about 18months.
As it gets used about 3 times a year, I've ignored it ;D
« Reply #10 on: 29 October 2016, 19:44:24 »
Lol ;D switches first and report back ;)
But I have a further hunch if all checks out ok...
powerslinky
« Reply #11 on: 29 October 2016, 19:46:59 »
Yes Nick . . . . same here really  . . .not gonna be a real  problem as will  very rarely use it
Just wondering what the cause is  . . . & if an easy fix I will . . .if not I won't
but will start with suggestions given so far  ;) ;)
powerslinky
« Reply #12 on: 29 October 2016, 19:48:42 »
Ok Doc   .  .will do  ;) ;)
  • Chatham, Kent
« Reply #13 on: 29 October 2016, 20:23:25 »
I suspect the switches are my problem, as the driver's window(the only one that matters) sometimes needs a long press to go down.
I'm ignoring that too, until it becomes a consistent fault or somebody posts a replacement switch panel through the letter box 8)
powerslinky
« Reply #14 on: 30 October 2016, 09:10:49 »
Ok  update . First swopped over both rear switches.. . same outcome o/s rear window will not close until ignition turned off /key removed/key returned & ignition turned back on.
Also changed drivers door switch bank for another . .. same result .
Put all original switches back in . . .still the same result.
BUT . . .  noticed that the o/s rear puddle light was not lighting when door was opened :o
So removed pin switch & spryed inside with switch cleaner  . . puddle light now comes on every time  . . .&   rear window is now operating as it should . . all be it a bit slow as it has probably not been used for quite some time .
Also  . . although the central locking worked from the fob when I got this car recently  . . . the dead locking did not. . .  now it works :o :o
Was the sticking puddle light pin the problem with the window & the dead locking, or have I just moved or touched something that has made these issues work again?  :-\ :-\
It seems fixed so thanks guys for your input :y :y
I will however start another thread on the subject of the central locking not re-setting when you put key in turn to position II & push lock . .  .as this another fault I need to look at
