Having OOF Techie issues
Started by zirk, 31 October 2016, 17:02:08
zirk
#15
Pc is on Vodafone access now. test....
Edit. Tea that worked,
Edit. Modify, test....
zirk
Quote from: zirk on 31 October 2016, 18:49:23
Tea that worked,
Modify, test....
Quote, test.....
zirk
Yep, all works fine on Voda, so I reckon must be a IP Range issue.
So its Evil Everywhere, when get 149.255.0.0/16 range? What about if you get another IP in another range?
zirk
Quote from: TheBoy on 31 October 2016, 18:52:52
I'll try EE on another IP, wait one.
EE test
[edit] This worked for me on EE, IP was 31.98.7.0/24
relluf
ee test
or rather EE Wales test
biggriffin
Fine here in hoof'land on vm and ee  :y
Hoof'land storeman.
zirk
Ok, put it back on EE, went from 149.254.XX.XX to now 149.254.YYY.YYY
Still the same, cannot post / reply.
Nothing 149.0.0.0/8 in configs this end.
Comes in from Zen Internet on wan1
Routed to routed IP vlan
Through f/w
Through L2 (only) switch
Through to relevant hypervisor
Through hypervisor virtual switch
Through to VM holding OOF's webserver
From webserver
To L2 switch
Through f/w
Routed from routed vlan to load balancer
Sent out via wan1 towards Zen Internet
Nowhere in there is anything I can see that would drop/redirect traffic to/from 149.0.0.0/8.
What are you getting when it fails? The Post button fails to respond? The page times out?  A webserver generated error message (like 404 or 501)?
Not that you're direct traffic would cause you're IP to go between the webserver and the database servers, but no IP level blocking their either.
Your problematic range is not in the SMF banned list.
zirk
Quote from: TheBoy on 31 October 2016, 19:16:16
Through f/w
From webserver
To L2 switch
Through f/w
Ok, no errors or timeout, if I try and Post Reply, Modify or Quote, thats all fine lets me type etc, as soon as I hit Post, it redirects me to a Blank Start New Topic on the same Board Im on.
ie - http://www.omegaowners.com/forum/index.php?action=post;board=9.0
strange thing is, I tried using Quick Reply and it lets me do that.
Gaffers
It's fine here too.
Take the hint maybe ?   ;D
