Author Topic: schrader valveon fuel rail (2.5 v6)  (Read 2792 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 31 October 2016, 19:27:55 »
bit of an odd one.
after replacing cam cover gaskets I got a strong smell of fuel. found a leak at the rail Schrader valve. tightened it up with a tyre valve core remover tool thingy. all good.
yesterday smell of fuel again  ???
sure enough the valve is leaking again evenafter I tightened it up.it was loose again. I again retightened but that hasn't madea bit of difference.
is the core just a standard tyre valve core? If so im going to fully remove it and swap it to see if that helps. if not I have spare inlets so can put them on. but obviously rather not have to have all that out...... again  ::)
cheers chaps
RIP Paul Lovejoy
Re: schrader valveon fuel rail (2.5 v6)
« Reply #1 on: 31 October 2016, 19:29:53 »
It would be same size I believe, but not sure if its different seals in order to cope with petrol etc...
Webby the Bear
  • Northampton
« Reply #2 on: 31 October 2016, 19:46:58 »
thanks Jaime. ill whip it out (the Schrader valve) andsee what I get  :) :) :) :y :y :y
RIP Paul Lovejoy
« Reply #3 on: 31 October 2016, 20:26:01 »
Glad you cleared up exactly what you were going to whip out.
Webby the Bear
  • Northampton
« Reply #4 on: 01 November 2016, 20:27:10 »
Well easily sorted. Got the valve out and it were bent. Replaced it with one out of a new tyre valve. Job done  :y
RIP Paul Lovejoy
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #5 on: 02 November 2016, 13:36:11 »
Good to know! Very good of them to use a standardised part, not make it 3 thou larger and be £19.76 + vat!
