Pages: 1 [2] 3  All   Go Down
Author Topic: Vauxhall Omega 2.2 CD 2003 wing mirrors  (Read 12456 times)
dave-b
  • Wigan, Lancs.
    • Elite 3.0 F/L
Re: Vauxhall Omega 2.2 CD 2003 wing mirrors
« Reply #15 on: 05 November 2016, 03:19:36 »
Whilst on the subject of mirrors, how can I disable the auto-dimming on my FL elite, I hate it. I have managed to get rid of it on my Vectra by putting a bit of silicone in the rear facing sensor in the the interior mirror, but there isn't one on the Omega that I can see.
« Reply #16 on: 05 November 2016, 08:34:52 »
Swap it for the standard mirror and simply tuck the plug up under the headlining ;)
Quite why you would want to is a puzzle though... it's one of the more useful Elite bits ::)
« Reply #17 on: 05 November 2016, 11:10:46 »
Sensor is the black dot in the corner.
But its plug and play with a non Elite mirror, which would then give you a manual dim option like other cars.
« Reply #18 on: 05 November 2016, 11:11:09 »
Assuming not a late 3.2 with rain sensors....
dave-b
  • Wigan, Lancs.
    • Elite 3.0 F/L
« Reply #19 on: 05 November 2016, 13:15:25 »
I just find it easier to judge the true distance of vehicles behind on an unlit motorway for example.
Obviously I can unplug it but that would remove the auto-adjust with the seat memory buttons.
« Reply #20 on: 05 November 2016, 16:44:53 »
3.0 ;)
How often do you move the seat? Moving the mirror is hardly difficult :-X
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
« Reply #21 on: 09 November 2016, 19:19:38 »
All Facelift Omegas have heated mirrors... If one side doesn't work then it's either a broken wire or the mirror has been replaced with a non heated cheapy ;)
Be surprised if any Omega doesn't have heated mirrors tbh, even my Facelift mk2 Granadas had heated mirrors.
Just checked my mirrors on my CDX, only the driver's mirror has the heated symbol on it. Is it easy to change the passenger mirror?
« Reply #22 on: 09 November 2016, 21:14:01 »
Yes, see above...
None of my Omegas had a heated symbol on them. All were heated...
See links above for suitable glass ;)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #23 on: 09 November 2016, 22:48:47 »
Both mirrors are heated on a CD/FL..  I have a Z157/OS complete here off the 2.2 i once owned
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« Reply #24 on: 10 November 2016, 09:14:19 »
Start the engine and put on the rear window demister. Then put the back of your hand on each mirror and then on the side window. If working the heated mirrors will be warmer that the side window. This is how I tested the new heated mirror glass. If both of yours are working then no need to replace.  :y
« Last Edit: 10 November 2016, 09:20:08 by Andy A »
atann
  • Canterbury
« Reply #25 on: 10 November 2016, 20:45:28 »
I'll give it a go tomorrow. Will update then. Cheers for the replies.
atann
  • Canterbury
« Reply #26 on: 10 November 2016, 21:39:48 »
The line on the mirror, what does it do? Is it for blind spot detection? My passenger mirror is without this line.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #27 on: 10 November 2016, 22:10:22 »
Look in it as someone overtakes you, you,ll soon find out. :y
« Reply #28 on: 11 November 2016, 18:48:02 »
It defines the wide angle end. Replacement glass has either heated/not and wide angle/not and blue tinted/not and stick on/clip on...
Nearest to factory is heated wide angle clip on. ;)
atann
  • Canterbury
« Reply #29 on: 11 November 2016, 21:18:10 »
Tried it today. Both mirrors heating up. Is it worth replacing for wide-angle? That stops a blind spot?
Pages: 1 [2] 3  All   Go Up
Page created in 0.022 seconds with 20 queries.
