Author Topic: Starter motor issue  (Read 2007 times)
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
Starter motor issue
« on: 03 November 2016, 20:11:12 »
Having a starter issue: On a number of occasions recently I have turned the ignition only for nothing to happen. If I continue to try and start it has so far eventually kicked in. Is the starter on the way out or is there a way I can overhaul it?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Starter motor issue
« Reply #1 on: 03 November 2016, 20:16:51 »
when you say nothing happens, as in silence?, any clicking?, when it happens next time put the headlights on, do the lights dim?
zirk
  • Epping Forest
« Reply #2 on: 03 November 2016, 20:19:09 »
Just sen its a 3.2, so Auto, try in Neutral and or Park give the Gear lever a wriggle.
berserkerboy
« Reply #3 on: 04 November 2016, 12:07:56 »
Gave the lever a wiggle. This didn't solve the issue. There was a very quiet click, not the kind of click I would associate with a solenoid problem. I am sure the battery is okay but will measure the voltage. :(
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 04 November 2016, 15:55:02 »
All connections checked inc. grounding (earth  ::)) strap underneath?
