Author Topic: 2.5 v6 ecu  (Read 2247 times)
Omega russ
  • Wrexham
    • Vauxhall omega 2.5 v6
2.5 v6 ecu
« on: 13 November 2016, 08:35:44 »
Does anyone know if you swap the ecu on a 2000 2.5 v6 do you have to program it or are they plug an play
Re: 2.5 v6 ecu
« Reply #1 on: 13 November 2016, 09:05:23 »
Plug and play, but...
You also need the immobiliser ring from the ignition barrel and the chip from the key. Car pass would also be nice :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: 2.5 v6 ecu
« Reply #2 on: 13 November 2016, 12:17:11 »
The Maps are different between Auto and Manual (it will still work) but you can swap the Eprom containing the Map easy enough.
Omega russ
  • Wrexham
Re: 2.5 v6 ecu
« Reply #3 on: 13 November 2016, 12:19:36 »
Ok thanks
My mate thinks my ecu is faulty
Had a problem yesterday my car wouldn't start
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: 2.5 v6 ecu
« Reply #4 on: 13 November 2016, 12:24:16 »
There are much more likely candidates than the reliable ECU.
Omega russ
  • Wrexham
Re: 2.5 v6 ecu
« Reply #5 on: 13 November 2016, 12:41:37 »
The ecu was hard to communicate with vaux com an kept kick us out
Then all of a sudden it fired into life no fault codes or anything
02 sensor 2 is reading high an the values don't move at all
zirk
  • Epping Forest
Re: 2.5 v6 ecu
« Reply #6 on: 13 November 2016, 13:27:05 »
Crank Sensor (1) is normally the first culprit for non start or intermittent start on the V6's, or Transponder Chip / Immobilizer issue (2).
(1) Doesn't always throw a Code.
(2) Was there any flashing EML when trying to start car.
Omega russ
  • Wrexham
Re: 2.5 v6 ecu
« Reply #7 on: 13 November 2016, 20:52:18 »
No light flashing or anything
The car was cold as it was first thing in the morning
Re: 2.5 v6 ecu
« Reply #8 on: 14 November 2016, 18:18:02 »
Depends on age....
....but it ain't a faulty ecu.
Re: 2.5 v6 ecu
« Reply #9 on: 14 November 2016, 18:20:05 »
Contact Ilexa, you should have some access to their tech support why its not communicating properly
