Author Topic: 17" tyre size  (Read 2399 times)
jayten1020
  • luton
    • 3.2 v6, 2.5td
17" tyre size
« on: 13 November 2016, 11:46:24 »
My 2.6  estate has on the rears 255/45/17 are these standard stock size or not?
Cheers
Joel
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: 17" tyre size
« Reply #1 on: 13 November 2016, 11:54:50 »
No.
235/45 17 is the stock size. It's also used on Mondeo and Passats so  isn't hard to find
jayten1020
  • luton
    • 3.2 v6, 2.5td
Re: 17" tyre size
« Reply #2 on: 13 November 2016, 12:06:46 »
So should I take them off and refit 235/45/17?
  • Chatham, Kent
Re: 17" tyre size
« Reply #3 on: 13 November 2016, 12:22:43 »
If they're not rubbing anywhere, then I would just use them up.
In theory your speedo won't read correctly, but the difference is small and probably doesn't matter.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: 17" tyre size
« Reply #4 on: 13 November 2016, 12:37:24 »
Tyre width wont effect Speedo.
Speedo comes from the Front anyway.
As Nick say if there not rubbing and work, replace both when needed.
  • Chatham, Kent
Re: 17" tyre size
« Reply #5 on: 13 November 2016, 13:29:06 »
A 255/45 tyre will have a larger fitted diameter than a 235/45. This must affect the gearing, and consequently the speedo. But it's a small difference, and probably doesn't matter.
I thought the speedo was driven off the rear wheel sensors?
powerslinky
Re: 17" tyre size
« Reply #6 on: 13 November 2016, 14:06:19 »
 would agree with Nick on this  . . . tyre wall height is 45% of the width  . .
So 45% of 255  is greater than 45% of 235   which would make the the O/A diameter of the wheel with a 255-45 tyre fitted slightly bigger than if a 235 - 45 was fitted .
Not sure how much of a difference it will actually make to speedo reading though :-\
Re: 17" tyre size
« Reply #7 on: 13 November 2016, 23:29:40 »
This ;) :y
