Pages: 1 [2] 3  All   Go Down
Author Topic: Omega breakdowns - Crank sensors and aux belt pulleys  (Read 9906 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Omega breakdowns - Crank sensors and aux belt pulleys
« Reply #15 on: 15 November 2016, 18:46:56 »
I don't know whether TB has changed crank sensor at roadside or not-but I have,however it does help that I'm built like a biro refill ;D ;D
How did you raise the car securely? A high kerb is fine if you can reach one without engine power.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #16 on: 15 November 2016, 18:52:08 »
Didn't raise car at all.Turned steering to full lock to give a bit more clearance and then I can reach bolt that holds crank sensor.Hardest bit is turning steering without the engine running!
terry paget
    • 3 Astras 2 Vectra
« Reply #17 on: 15 November 2016, 19:24:02 »
Congratulations! It never occured to me it could be done with wheels on the ground.
« Reply #18 on: 15 November 2016, 19:26:29 »
But again, it isn't a bad enough problem to spend any time worrying about it.
Both times mines failed away from home, its been game-over - its not viable to do 2 miles every hour when you're 500 miles from home.
Certtainly worth carrying a £45 sensor in boot, along with an e8 socket ;)
    • 530D M Sport, 330i Coupe
« Reply #19 on: 15 November 2016, 22:12:27 »
Agreed, also would say the same for a HBV, bit more fiddly to fit at the roadside and sometimes you can keep the coolant from escaping by running on full heat or full cold but a fix at the side of the road is far more preferable than on the back of a recovery truck - especially if your a hundred miles or so from home, which I am pretty much every day.
« Reply #20 on: 16 November 2016, 17:52:40 »
I know you love your Omegas Andy, but surely if you were genuinely that worried, you would be driving a shiny new lease car...
I always work on the basis that recovery can get the car home and I can then fix/torch it as appropriate. Hasn't failed yet :D
terry paget
    • 3 Astras 2 Vectra
« Reply #21 on: 17 November 2016, 17:05:59 »
Recovery is all very well, but it can take a while to arrive. Happily all Omegas come with full size spare wheels and wheel changing kit, so punctures don't bother us. Crank sensors usually recover on cooling and allow us to proceed, but 16 year old aux pulley bearings can seize without warning and then we are stuck.
I appreciate one can get carried away preparing for unlikely breakdowns, but popping into the boot an old belt and a spare pulley adds little weight. I already carry an extensible wheel nut tool, all I need is a 15mm socket and I can be on my way in less time than a wheel change takes.
« Reply #22 on: 17 November 2016, 17:53:21 »
.... Happily all Omegas come with full size spare wheels and  ....
Almost full size  ;) ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #23 on: 17 November 2016, 18:03:26 »
That's always been my approach; even when running 20 year-old £25 cars as daily drivers(600 miles a week) for several years, I've never found any need to carry tools or spares beyond new points and condenser - and only from the early '90s when the quality dropped through the floor and failure rates rocketed. I did once use the AA patrol's tools to refit a Pinto cambelt, rather than have it towed home, but I was on my way to a party. The only reason my large socket set is now in the car is that I no longer need it for work and have nowhere else to keep it. I have always fixed stuff as soon as it presents a problem, whether it was a funny noise due to a failing drive belt or buying some new bellhousing bolts when changing gear on roundabouts became impossible.
13 years driving a recovery truck actually reinforced this opinion. I'm not buggering about with my car at the side of the road. I can just about accept keeping a working when it was removed(the real definition of known good) crank sensor, but a HBV/alternator belt/tensioner pulley? Those fall into the same category as holed sumps or suddenly leaky radiators - possible, but not common enough to worry about.
« Last Edit: 17 November 2016, 18:05:02 by Nick W »
  • Chatham, Kent
« Reply #24 on: 17 November 2016, 18:04:43 »
Matching alloy and 235/45 17" tyre in my wheel well 8)
« Reply #25 on: 17 November 2016, 18:26:56 »
Alot to be said for having an estate...
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #26 on: 17 November 2016, 19:29:48 »
This works for you, so fine, but, for me, if I am on holiday touring in Scotland or Europe, I have no wish to be recovered to home for something as simple as those described above. :y
« Reply #27 on: 17 November 2016, 20:14:01 »
Agreed, I work all over the country and nothing is worse than having to endure a return journey from places such as Newquay or Aberdeen to Solihull in a recovery truck or multiple recovery trucks. I try to look after my cars and ensure all the essentials are checked regularly but even so I also carry the items above plus some oil and water (cars with HID's and washers seem to drink 5L of washer fluid in no time this time of year!). It's no big deal weight wise as the car is always loaded up with kit for my job anyway.
tidla
  • solihull
« Reply #28 on: 21 November 2016, 10:37:17 »
Yep, heat setting on full helps get you home when the hbv throws a wobbly.
Battery terminal is another gremlin , but only needs doing once.
tidla
  • solihull
« Reply #29 on: 21 November 2016, 10:38:17 »
Abs unit. phone gps app with speed helps with that ;D
Pages: 1 [2] 3  All   Go Up
