Before I buy Help
Started by grifter, 15 November 2016, 18:52:14
EMD
Quote from: grifter on 15 November 2016, 18:52:14
Hi Guys/Gulls
I have just joined as am very keen to purchase a 24 v6 CD Omega Auto, it's relatively low miles, looks in good nick, verified miles and MOT, which is out to April 17.
I am looking for some pointers as for things to check apart from the obvious things. Do you have a guide on here I can go through? I'm an ex mechanic and run several other cars including have an old 3.0 senator and a few cavys too so got the mechanical know how, and "the feel" of the vauxhall way of making things! Omegas I've no experience with but I'm sure they are just senators with a lot more electrical gubbins and a v6 instead of ------ 6 :)
Hopefully I get it and can get a bit more active in here.
Ta for now
G
What cavs are you running grifter ?
Omegatitis
grifter
Quote from: ronnyd on 16 November 2016, 23:53:50
Try holding button down for about 5 seconds, it,s caught a few people out, including me. ::)
That worked thanks!
grifter
Quote from: EMD on 17 November 2016, 12:49:24
Hi EMD I'm running a 1.8 ls and have a diplomat 2.0 auto, which is garaged right now.
grifter
#18
I did intend to pop in to have more of a look today at lunch time but the shop was shut so I came back about half 4 and he was there. First thing I done was shine the torch down the back of the chassis legs in the engine. Strange thing I seen down the N/S at the back was water coming down onto the chassis leg at the very back. It had been raining. There wasn't any rust but it looked like the water was coming out near the bulkhead. Is there a water drain there or has it found it's way from somewhere else?
Tyres on front are toast, the inner threads of the tyre are showing on the inner edges, and on the outer edges, while not exposing the carcass of the tyre, are baldy. There is a little tread on the middle but as I said they are well beyond legal. I'd said to him that likely the front arms need redone. He said he didn't hear anything while on the road, like any clunks. So would the worn tyres, on the inside especially, point to bushes worn out?
Another thing I came across was in the engine bay. I turned ignition on, but didn't start, went round and opened bonnet, had a wee quick check before going to start it and I heard this buzz sound like an electric motor but a bit rougher, maybe like a stepper motor, from the top of the engine. Sort of like a fuel pump prime sound or something. What could that be. It did stop after a few seconds. It buzzed for a second, then off then again and then that was it.
What I did also notice when engine was cold running was it sounded a bit piston slappy when I gave it a little rev. I'm taking it these engines are not "BMW 6 cylinder" smooth, especially when cold? It didn't sound mechanically anything wrong just maybe a wee bit noisier than I'd expect from a newer type v6. I've no knowledge of these so nothing to base it on.
So got a test drive tomorrow - he can drive it with those tyres like that lol as I don't want my collar felt.
The worn tyres are a combination of bad wishbone bushes, worn track-rods and shock absorbers and consequent poor alignment.
These are typical Omega problems, and are why we suggest that you should always budget for a front end rebuild(wishbones, shocks and their bearings/top mounts, track rods all at the same time)  followed by  an alignment by someone who knows what they are doing, on any new-to-you example.
BazaJT
There is a "flap" in the n/s of the scuttle panel,which gives access to the pollen filter.In the bottom n/s corner of this space there is indeed a scuttle drain which empties to [obviously] the n/s.Check the drain isn't blocked-it doesn't sound like it is-as if the space fills with water it over flows into the car and generally takes the heater "hedgehog" out.
Quote from: Nick W on 17 November 2016, 18:41:57
And worthwhile doing the rear trackrods as well... Get it set up right once.;)
The Omega will sail through an MOT with knackered wishbone bushes because they are all but hidden inside the subframe. Budget to fit a pair of GM bushes at the rear of wishbones and a pair of polyurethane bushes at the front and be pleasantly surprised at the transformation.
Inner edge front tyre wear is caused by too much front camber. It is adjustable but garages either flat out refuse to adjust it or set it to the official figures (which are way out). Sort out the bushes first, then the camber then the toe then fit some new tyres.
If you are looking at a 2.6 or a 3.2 drive-by-wire I thing the whirring noise is the throttle doing a self test :-\ (I don't think a CD will have an air compressor for self levelling suspension)
My current 2.6 sounds slappy when it is cold but I don't know if it is pistons or cam followers or something else - it has done over 200,000 miles now and sounded exactly the same when I bought it at 115,000 miles.
grifter
#23
I guess it's easier to get the bushes rather than whole arms, so a set of bushes, top bearings, shocks and tracks. Are we talking the 4 wheel alignment? I got mine done at kwik fit on the senator, they front N/S is still well out as the tyre is scrubbing on the inside and it slides at the drop of a hat on a wet roundabout i.e. front lets go. In other words would it be wise to body swerve kwik fit and go to a specialist?
Quote from: BazaJT on 17 November 2016, 18:57:58
Bit scary that it drips onto the chassis leg and seems to run down inside it, I think there is drain hole below the ABS unit - think it was abs unit - could hear it draining down.
Quote from: Andy H on 17 November 2016, 19:18:48
You might see I mentioned my senator 4 wheel alignment above in reply to Nick. I only discovered the senny had this adjustment after I had removed the strut bolts, when I was refitting I noticed that with the top bolt in the hub the strut was still lurching back and forth until it hit the bolt. I had no marks on strut holes for bolt as it was new struts, oops. I wasn't sure of setting so I bought these offset bolts and got kwik fit guy to do 4 wheel alignment, where the front at least N/S is still well out even though his print out had the little green. I take it it is exact same set up on omega?
I did think that noise was some sort of self test, it did sound right on top where throttle body is. While on that subject I checked around engine fittings and none of the little torx screws look chewed up or anything as if it's been apart before, and no signs of bodging electrics or anything else, apart from a wee bit of tape round that vac pipe on brake servo pipe.
Well test drive tomorrow, see how that goes.
Many thanks for all your advice so far, appreciate it very much and is invaluable of course when setting out to buy a car you are n't that familiar with.
Will let you know how it goes tomorrow.
G
LC0112G
#24
The problem with these 'old' cars is deciding whether you trust/believe the seller. If they tell you it's had recent front end rebuild and a new timing kit, then great you're good to go for another 20-40K miles without having to spend much on new parts. However, if you don't trust them, or if they say it hasn't been done then it can get expensive.
I think I read this car is 78K miles? If so, then has the timing belt been done recently? Service interval is 40K so it's either due to be done soon, or has been done recently?
My finger in the air costings of stuff I'd want to do are...
Timing Belt & Water Pump £300
Front wishbones £100 a pair
Drop links & track rods - £100 ish.
Shocks - dunno - anywhere between £10 and £500 each.
Tyres - 2 or 4 off at £100 each (for a decent brand)
Brake pads and discs - £100 an axle.
Standard service  (Oil, Oil filter, fuel filter, spark plugs) - £50 ish.
So you could easily spend a grand on parts and that doesn't include the cost of fitting them - although it seems you have the skills to do that yourself.
Oh and if you do start working on it yourself, buy yourself a good set of torx box spanners. And read up on changing the fuel filter (those effing stupid clips!). >:(
ETA : Oh and while doing the first oil change I'd be dropping the sump plate off too to make sure the oil pickup is clean of silicone sealant. Relatively simple job, but you'll need the grey sealant to put the sump back on.
EMD
Quote from: grifter on 17 November 2016, 18:09:04
Got a 1.8 manual club here , 93 vintage in Polar sea blue :y
Omegatitis
Generally "Four Wheel Alignment" means hanging some gauges on rear wheels whilst shining a narrow beam of light or laser from front.  This isn't worth shit. Nothing. Zilch.
What you are generally after on an Omega, and certainly if the car is new to you, is a full geometry.  The front type shoulder wear is generally camber, although the long arms coupled with aggressive driving does tend to turn Omega fronts into a more, well, motorcycle profile.
Any such alignment specialist needs to understand that the original GM specs were a bit crap to start off with, and are utterly useless as all these cars have aged. So "computer says green, mate" ain't good enough either.  Fortunately, there are a handful of outlets around that actually understand what they are doing, not just do what the computer says.  We worked with Wheels-InMotion in Buckinghamshire to get a good baseline to work from.
grifter
#27
Quote from: TheBoy on 18 November 2016, 17:34:19
That's what the guy at kwik fit done with the senator, all within tolerance (green) yet at least one front was still way out. I will give the guy his dues he was quite genuine and probably really didn't know much more than the manual and computer was telling him plus he seemed a bit confused about the model of car he was adjusting for.
I've been reading up various ideas on the alignment, here's one a guy done for lotus carlton, which is same principal applies to senator, and I guess probably the omega too.
http://www.lotuscarlton.co.uk/camber.htm
I've got the official vx manuals online and it tells procedure there. This include loading up the front seats with 75kg, full tank of fuel, tightening knuckle bolt to certain torque then letting car weight on to it, tighten it higher torque etc. I'd probably end up doing that if I can't find a shop up here who really doesn't know how to do this, plus it's save me cash and I'd learn more!
When I drove it today it seemed quite straight and true on the road although I did at some point feel a little bit jittery when I hit a negative camber bit of road or a bumpy bit.  Probably the shagged tyres, potentially worn bushes/track ends didn't help things.
The Omega does seem a little prone to tramlining, and (assuming suspension is in good condition) its they tyres.  Some are awful from new (such as Conti SC5), some are downright lethal when half worn (such as Falken 452).
2 or 3 years ago, chrisgixer did post up a survey for tramlining, and which tyres are more prone on the Omega.
tidla
With polys fitted in the arms at the front and ( after replacing first line bushes after not very long with gm ones) and camber set at 1..10. tyre wear and weird handling is something ive never really  experienced.
