Author Topic: H1 and H7 bulbs  (Read 4222 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
H1 and H7 bulbs
« on: 18 November 2016, 17:18:37 »
Before I buy are the Osram Night Breaker or the Phillips Extreme more suited to the standard Omega 2.2 CD's headlights?
Anyone using either and what's your thoughts?
Thanks
amazonian
  • upper beeding. west sussex
    • 03 2.2 CDX auto estate
Re: H1 and H7 bulbs
« Reply #1 on: 18 November 2016, 17:26:24 »
I can only say that the nightbreakers I had on my old Dti were slightly better than the standard bulbs, but not as good as the xenons I have now. IMHO.
Andy A
  • Bristol UK
Re: H1 and H7 bulbs
« Reply #2 on: 18 November 2016, 19:16:31 »
Makes you wonder whether if its worth the change.
Thanks
steve6367
Re: H1 and H7 bulbs
« Reply #3 on: 18 November 2016, 19:52:54 »
Thanks
They are better, but not massively - also won't last as long. Having said that I have them in both of mine with Xenons.
Stargazer57N
Re: H1 and H7 bulbs
« Reply #4 on: 18 November 2016, 21:10:22 »
I fitted some Halford 120% brighter bulbs to my Omega the other week and they made a massive difference, I can actually see the animals before I turn them into roadkill now.  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: H1 and H7 bulbs
« Reply #5 on: 18 November 2016, 21:28:04 »
If they achieve that by higher wattages, you should be aware that the plastic headlamp lens melts easily.
Stargazer57N
Re: H1 and H7 bulbs
« Reply #6 on: 18 November 2016, 21:48:18 »
No it's not done by wattage just checked the box as I kept my old ones in them as spares and the new ones are 55 watts. Don't know how they work but they do.
steve6367
Re: H1 and H7 bulbs
« Reply #7 on: 18 November 2016, 21:58:43 »
Thanks
Without
Stargazer57N
Re: H1 and H7 bulbs
« Reply #8 on: 18 November 2016, 22:23:15 »
Andy I might be worth checking that your head light lenses aren't  tarnished/deteriorated as that has a massive difference to your light out put.
Andy A
  • Bristol UK
Re: H1 and H7 bulbs
« Reply #9 on: 19 November 2016, 09:21:07 »
I'll be out in the cold wet working on my son.s car brakes this morning. I will have a good look at them.
Thanks
atann
  • Canterbury
    • Vauxhall Omega 2.6 CDX
Re: H1 and H7 bulbs
« Reply #10 on: 20 November 2016, 03:03:52 »
My nearside light lenses is yellow and faded, though I have xenons in my CDX. Does the deterioration effect xenons as badly? Can't see much difference between my clear offside when reflected on other cars?
Andy A
  • Bristol UK
Re: H1 and H7 bulbs
« Reply #11 on: 24 November 2016, 15:08:19 »
Just got a set of H1 Osram Night Breakers. Fitted the O/S one and when it gets dark, will see if there is any difference between that and the N/S standard.
Also got the 3M headlight restore kit to try.
Thanks
