Author Topic: Speedo  (Read 3516 times)
EMD
  • Noofhampton
    • 95t
Speedo
« on: 23 November 2016, 11:57:13 »
Speedo keeps bouncing and not working every now and then  ??? Only seems to happen when its colder . soon as the car has warmed up on a run the speedo jumps into life  ??? New speedo or just a loose connection  :-\
Omegatitis
Re: Speedo
« Reply #1 on: 23 November 2016, 12:08:25 »
Try reseating the cluster...
But we've had this conversation before... bouncing leads to needing a new cluster when the speedo finally dies.
Presume abs/tc lights working as normal  :-\
EMD
  • Noofhampton
    • 95t
Re: Speedo
« Reply #2 on: 23 November 2016, 12:14:20 »
Aye  :)
Omegatitis
EMD
  • Noofhampton
    • 95t
Re: Speedo
« Reply #3 on: 01 December 2016, 10:50:41 »
Are all Omega speedo's the same ? There is one from a 2.2 16v for sale  :)
Omegatitis
Diamond Black Geezer
    • & a silly coupe coming...
Re: Speedo
« Reply #4 on: 01 December 2016, 11:01:13 »
Speedos all the same, I think, however, the whole binnacle will differ from petrol to diesel (think the glowplug light, for instance) so any old binnacle may well plug in fine, but you's no doubt have certain issues. Might well be possible to install just the speedo into your existing binnacle, thought suspect it's going to be far easier to get the 'right' one in the first place.
Yours is V6 yes? Should be the easiest binnacle to source on here, surely?
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Speedo
« Reply #5 on: 01 December 2016, 12:07:36 »
I have a 2.6 binnacle if you are wanting one EMD
Re: Speedo
« Reply #6 on: 01 December 2016, 12:20:34 »
No. 4 pots go to 140mph, V6 go to 160mph  :y
Re: Speedo
« Reply #7 on: 01 December 2016, 13:09:19 »
Bugger, yes, of course, 4 pots will read slower, too. I suppose the spacing between each increment would be different, too, throwing the readout off by a fair bit. have to check on the spares Omega, that's a 2.0...
Re: Speedo
« Reply #8 on: 01 December 2016, 19:03:41 »
Speedos vary with engine and age.  Pre 1998, its horrifically complex.
EMD
  • Noofhampton
    • 95t
Re: Speedo
« Reply #9 on: 05 December 2016, 14:40:44 »
Thanks for that offer omegod  ;) Ive taken the panel out then cleaned the connections . Seems to be working ok for now but wonder if its a sign its on its way out  :-\ It happened last year when the cold weather started but fine in the warmer months  ???
Omegatitis
