My Ford broke down today
Started by TD, 01 December 2016, 18:30:51
citroenguy
Quote from: tunnie on 02 December 2016, 08:03:29
New fuel filter is on my to do list on the VW, now I have VCDS software.
Glad it was a simple fix  :y
Is it necessary to go into the software to change the fuel filter??
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
Wouldn't have that problem if it ran on proper fuel ::)
biggriffin
Must have been, some serious water in that fuel, or just crap fuel, to start waxing at such a temperature, diesel nowdays in the northern hemisphere is good to at least -15, before winter additives.
Best start putting a drop of petrol in the tank (old skool rules) 8)
Hoof'land storeman.
Quote from: citroenguy on 02 December 2016, 08:57:29
You would hope not!
Should be a change and cycle the ignition 3 times for 30 seconds or so to re-prime the setup, I thought it was only Merc who required random programming for simple changes.  ;D :y
Quote from: biggriffin on 02 December 2016, 09:30:41
Its all this cheapo stuff TD keeps getting off his dodgy punters.  ;)
biggriffin
Quote from: Marks DTM Calib on 02 December 2016, 09:36:37
You mean the bleached red, from that Irish fella.
Hoof'land storeman.
Quote from: biggriffin on 02 December 2016, 09:40:04
Or the stuff some bloke recovered from a Milford Haven beach some years ago.
Quote from: Marks DTM Calib on 02 December 2016, 09:35:58
You would hope not!
VCDS triggers the prime cycle for the fuel pump/filter, so gets rid of the air. Forums suggest the ignition method was not advised on the later TDI's :-\
Also need VCDS to put rear electric hand brake in service mode, so you can change the pads.
Quote from: tunnie on 02 December 2016, 10:22:56
You would hope not!
Shite.design.com  ;) :'(
You would hope not!
BMW have done that for years too, battery changes on the 7-series for example.
Quote from: Marks DTM Calib on 02 December 2016, 11:38:02
You would hope not!
Perhaps from DIY work point of view, but when I considered the Insignia that had a shite.design.com/interior  :D
Quote from: tunnie on 02 December 2016, 12:13:56
You would hope not!
#mostirrelevantstatementever
 ;D
Would certainly rather sit in an Insignia than drive a VW :P
Have you tried a full scan yet?
Quote from: Andy H on 02 December 2016, 12:59:18
Yes, everything works. Took a scan few weeks ago, will take another one soon.
Just setting a laptop up with VCDS so I can keep an eye DPF, after about 3,000 miles it was fine, just 0.008g in there, having done a cycle fairly recently. Interested to see how quickly it builds up
