Pages: [1] 2 3 4 5 6 7   Go Down
Author Topic: mv6 just cut out??  (Read 28336 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
mv6 just cut out??
« on: 10 December 2016, 16:34:16 »
wonder if anybody can help ,,  the 2.6 just cut out today, and just will not start ,
thanks in advance
Re: mv6 just cut out??
« Reply #1 on: 10 December 2016, 16:35:06 »
Crank sensor is high on list of likely culprits
Any fault codes? :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #2 on: 10 December 2016, 16:53:48 »
MAF is worth considering too, especially if the car was trying to idle at the time it cut out.
swordfish
  • manchester
« Reply #3 on: 10 December 2016, 17:54:17 »
are aftermarket crank sensors worth buying
powerslinky
« Reply #4 on: 10 December 2016, 17:57:21 »
NO . . . IMHO  & many others on here  . . genuine only  .  .purchased by visiting  a VX dealer  . .
don't buy from internet or it will end in tears :'( :'( :'(
« Last Edit: 10 December 2016, 18:03:58 by Essex Big Al »
« Reply #5 on: 10 December 2016, 18:08:16 »
I have a perfectly good Genuine GM one here that will fit your car.
Used, but works fine.
It's only right that I advise you that new is better, for long term, but if it helps you test or gets you out of a hole..... :y
swordfish
  • manchester
« Reply #6 on: 10 December 2016, 18:18:20 »
great ,, how much posted please
swordfish
  • manchester
« Reply #7 on: 11 December 2016, 12:48:42 »
ok thanks,,
i have just noticed that there are no warning lights on the dash when i turn the ignition on . ??
swordfish
  • manchester
« Reply #8 on: 11 December 2016, 14:21:01 »
anybody experienced this before;;
thanks in advance
« Reply #9 on: 11 December 2016, 14:42:15 »
Does it still turn over? Is the computer display on? Headlights etc work?
  • Auckland
    • Mazda MPV
« Reply #10 on: 11 December 2016, 15:40:49 »
You need to do some basic electrical fault finding.
Check for blown fuses and broken wires (or loose crimped terminals) on top of the battery for a start.
swordfish
  • manchester
« Reply #11 on: 11 December 2016, 18:18:15 »
yes checked all the fuses , and all the connections  everything works and it spins over ok
  • Auckland
    • Mazda MPV
« Reply #12 on: 11 December 2016, 18:23:53 »
I thought you said that you had no warning lights :-\
swordfish
  • manchester
« Reply #13 on: 11 December 2016, 20:03:55 »
sorry no everything but ignition lights
swordfish
  • manchester
« Reply #14 on: 12 December 2016, 07:15:54 »
everything works apart from the ignition  lights
the ones in the speedo rev  cluster ??
Pages: [1] 2 3 4 5 6 7   Go Up
