Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: mv6 just cut out??  (Read 28351 times)
Re: mv6 just cut out??
« Reply #15 on: 12 December 2016, 10:36:46 »
A failed crank sensor won't necessarily put the engine management light on. Do the pefal trick & see what code (if any) it comes up with.
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
« Reply #16 on: 12 December 2016, 10:41:54 »
swapped the crank sensor already for the one off my other 3.2 and it still wont start
is there a how to guide on the pedal trick
thanks
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #17 on: 12 December 2016, 11:11:05 »
powerslinky
« Reply #18 on: 12 December 2016, 11:57:36 »
Think I am correct in saying that if crank sensor is ok . . as you turn ignition on the rev counter needle just flicks a tad .
But as you say you have no dash lights at all  . . . so this may not be the case in your situation as the whole dash pod may not be working  :-\    If not already done  . .. try reseating the pod by pushing firmly towards front of car . But IMO unlikely an incorrectly located pod would stop the engine from turning over.
I would be asking the question on here of  which fuse/fuses or earthing points are liable to stop these dash lights from coming on .  HTH :y
« Last Edit: 12 December 2016, 11:59:36 by Essex Big Al »
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #19 on: 12 December 2016, 12:03:48 »
thanks
I thought they were type specific? :-\ :-\ :-\
powerslinky
« Reply #20 on: 12 December 2016, 12:12:34 »
thanks
Post no. 1 says 2.6       . . . .  2.6 & 3.2  use the same crank sensor I believe
swordfish
  • manchester
« Reply #21 on: 12 December 2016, 12:21:15 »
well that stops the pedal trick  because no dash lights to flash up ,,
could it be ecu immobilizer failure ,, or dash pod failure i wonder ??
powerslinky
« Reply #22 on: 12 December 2016, 12:31:01 »
Sorry have just read through complete thread again  . . .So engine does turn over but will not start   & there are no dash lights at all in any key position?
Is there any life from the dash pod at all ? are indicator greens working when switched on  , main beam blue when flashed? background lights for dash etc. ?
« Last Edit: 12 December 2016, 12:39:39 by Essex Big Al »
swordfish
  • manchester
« Reply #23 on: 12 December 2016, 12:49:46 »
correct , everything works but the dash pod lights and it spins over as it should
powerslinky
« Reply #24 on: 12 December 2016, 13:00:05 »
Electrics are not my strong point sadly ,so you may to wait for a more knowledgeable oofer to reply,
but if no warning lights at all, it may be worth checking out the ecu connection in the main   relay/fuse box next to the battery. (black triangular shaped box . . lid flips from the front) may be worth unlatching & relocating the ECU connection  :-\ :-\   but only a suggestion
Also there a  couple of main electrical push in  connector blocks below/side of battery area :-\
« Last Edit: 12 December 2016, 13:03:19 by Essex Big Al »
swordfish
  • manchester
« Reply #25 on: 12 December 2016, 13:04:24 »
ok thanks
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #26 on: 12 December 2016, 14:53:24 »
Check the separate Black Earth Cable strap to the ECU is not loose, check the 2 ECU main plugs are tight, or undo re connect them, check all your Battery terms and main Earth is all tight etc. on the 2.6/3.2's just before you crank the Engine you should hear some relay clicks type sound from the throttle Boddies and the purple relay(s) in the front fuse box.
« Reply #27 on: 12 December 2016, 19:20:22 »
Are you saying the engine lights do NOT come on with ign? If not, fix that first.
swordfish
  • manchester
« Reply #28 on: 13 December 2016, 09:38:27 »
i have just checked. the lights work main beam and warning light works indicators work and i can here the clicking relays nr the battery ,,it seems its just the warning lights in the pod  that are not  coming on
swordfish
  • manchester
« Reply #29 on: 13 December 2016, 10:08:09 »
i have just fitted a new  pod but still no ignition lights
Pages: 1 [2] 3 4 5 6 7   Go Up
