Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: mv6 just cut out??  (Read 28332 times)
powerslinky
Re: mv6 just cut out??
« Reply #45 on: 16 December 2016, 16:06:46 »
Thank god for that you are a brave man playing with those fuses :y
Why ?    can you explain ? , as if it will cause problems I would like to warn OP before he touches his .
But it would seem there are no issues after pulling mine  :-\ :-\
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
« Reply #46 on: 16 December 2016, 16:16:20 »
ok thanks for that i will try it out on monday  :y :y
powerslinky
« Reply #47 on: 21 December 2016, 08:43:35 »
Any news on this Swordfish ?     :-\ :-\
swordfish
  • manchester
« Reply #48 on: 07 January 2017, 10:46:12 »
just checked power at the fuse conection and getting full 13 volts
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #49 on: 07 January 2017, 11:10:34 »
That's not really enough, and points to a charging issue. Checking all of the battery and alternator connections is now first on your list of things to do.
swordfish
  • manchester
« Reply #50 on: 07 January 2017, 11:24:05 »
how can it require more than 13 volts  :-\ :-\
powerslinky
« Reply #51 on: 07 January 2017, 11:29:01 »
I think Nick means that with engine running , and therefore charging, reading should be around 14.4 volts
Hence he mentions charging issue
With engine not running usual reading with a good battery is circa 12.4 volts  :-\
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #52 on: 07 January 2017, 11:40:11 »
Sounds like an ECU issue to me....
Manual and Auto ECU's are different.... dunno if you can fit an Auto ECU to a manual, but its worth a try just to see if the warning lights illuminate..... maybe try to start the engine but not drive it...?
D.I.L.L.I.G.A.F...
swordfish
  • manchester
« Reply #53 on: 07 January 2017, 11:43:05 »
already swapped them inc the immobilizer ring
powerslinky
« Reply #54 on: 07 January 2017, 11:49:08 »
so you have changed the engine ECU , imomobiliser ring & key chip ?
 and you still have no dash lights ?
 Could the ignition switch itself be at fault here ?  as in operating the starter circuit in position 3 but not switching ignition circuit on in position 2 ?
swordfish
  • manchester
« Reply #55 on: 07 January 2017, 11:51:19 »
yes
powerslinky
« Reply #56 on: 07 January 2017, 11:58:00 »
yes
I added a bit to my last post about the ignition switch.
Maybe it is fubared & although switching on the starter circuit in pos 3   . . .it has failed & wont switch on the ignition , relays,  ECU circuits  (in  normal running position 2 )
the old term "hot wire"  would be applicable here to test . but be careful  . . .you have to make sure you are connecting the correct wires here , otherwise serious damage may occur.
Someone on oof with a good understanding of the ignition switch wiring may be able to tell you which wires to test & "hot wire"    Caution here is very important  ;) ;)
« Reply #57 on: 07 January 2017, 11:58:53 »
You have replaced the dash bulbs?
swordfish
  • manchester
« Reply #58 on: 07 January 2017, 12:00:15 »
replaced the full dash pod
« Reply #59 on: 07 January 2017, 12:02:03 »
Didn't answer the question...
In any case would need to be from same engine type.
Pages: 1 2 3 [4] 5 6 7   Go Up
Page created in 0.025 seconds with 20 queries.
