Author Topic: Estate Passenger Side Wheel Bearing  (Read 10708 times)
steve6367
« on: 15 December 2016, 18:19:25 »
I have a worsening drone form the rear, gets worse when weight put on that wheel and better when cornering the other way.
Reading the posts on here I don't think I can do it at home.
£307.20 at local garage - seems a reasonable price based on how long it could taken them?
Does anyone on here do them for beer tokens? (I don't mind helping)
Steve
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Estate Passenger Side Wheel Bearing
« Reply #1 on: 15 December 2016, 18:32:24 »
I've done several in the street, and reckon it's about a two hour job.
The bearing is £25 to 50 depending on how much of a risk you're prepared to take on a cheap one.
Where in the country are you?
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 15 December 2016, 18:37:42 »
Steve
My local indy replaced them for £40 each. :y
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 15 December 2016, 19:40:51 »
not sure where about are you ,
FAG or SKF bearing supply and fit £100 +vat
steve6367
« Reply #4 on: 15 December 2016, 19:47:37 »
Thank you for the replies, I m in sunny Dorset.
Looks like I need to  shop around more or travel!
serek
  • huntingdon
    • 3.2 mv6
« Reply #5 on: 15 December 2016, 19:55:35 »
there got to be a local member on forum who will be able to help  :y
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #6 on: 15 December 2016, 22:06:54 »
Before you start dismantling the car, I'd just confirm that the problem is actually the wheel bearing and not a tyre issue.  A deformed tyre or a cheap budget tyre can sometimes make a droning noise that can be mistaken for a wheel bearing. I know you have stated it gets worse when cornering which would tend to indicate a wheel bearing problem, but I still think checking it's not a tyre issue whichever  would be an easy check that may save unnecessary work and expense!
« Last Edit: 15 December 2016, 22:11:46 by johnnydog »
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #7 on: 15 December 2016, 22:46:25 »
Have you actually jacked the car up to find out if there is play in the bearing or are you just basing it on noise alone? Also, might not be the side you think it is due to the sound travelling across the car, (if that makes sense).
Shackeng
  • Ramsbury
« Reply #8 on: 15 December 2016, 23:36:35 »
Does anyone on here do them for beer tokens? (I don't mind helping)Steve
Sorry I should have said I supplied the bearings. :y
steve6367
« Reply #9 on: 16 December 2016, 08:39:38 »
Thanks for the reply - I've had it up in the air and can detect no play, but I m not sure what else it would be. The sound is very metalic. I had not considered tyres so will swap them left to right and see if the noise moves to be sure.
steve6367
« Reply #10 on: 16 December 2016, 08:40:21 »
Yes there is no play but assume the bearing can be noisy first?
« Reply #11 on: 16 December 2016, 09:58:13 »
In a manner of speaking, yes. Perceptible play occurs a time after noise starts :y
106pete
  • Plymouth
    • Omega 3.0 elite
« Reply #12 on: 16 December 2016, 10:24:22 »
My bearing had no play at all but made a hell of a drone from the rear
It's a easy job if you know what ur doin and have the right kit  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #13 on: 16 December 2016, 11:05:24 »
Make sure your tyres are not directional before swapping :y
« Reply #14 on: 17 December 2016, 07:18:14 »
I had no play at all in mine but the bearing was dry as a nun's... It had been droning for several months and had gotten so noisy you couldn't hold a conversation without shouting!
