Author Topic: sorry work releated question....  (Read 1168 times)
« on: 30 July 2008, 11:22:56 »
... does anyone know of a decent bulk IP whois lookup service?
I am going to have a huge list of gateways which i need to look up, to find the carrier they came from.
Last time it was limited numbers and i just did a manual request on linux box, but don't really wanna do that 200 times.
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: sorry work releated question....
« Reply #1 on: 30 July 2008, 11:35:36 »
you still have access to a linux box??  if so, export the IP addresses into a file (one per line), and then create the following bash script
whois_bulk.sh
Code: [Select]
#!/bin/bash
for i in `cat $1`
do
  whois $i > whois_$i
done
set the file to executable (chmod +x whois_bulk.sh) and then run it
./whois_bulk.sh inputiplist.txt
it will create a seperate whois for each IP address (whois_xx.xx.xx.xx), and so-on...
« Last Edit: 30 July 2008, 11:35:55 by PaulW »
Humbugs...
PaulW
« Reply #2 on: 30 July 2008, 11:38:27 »
also, if you want to stop the whois servers going haywire, after the line
whois $1 > $whois_$i
put
sleep 2
to make it wait 2 seconds (increase/decrease as required)
Also, if you want certain parts, grep the output (if you just want descr tags)
whois $1 | grep descr > $whois_$i
will return:
gsi ~ # whois 217.155.56.220 | grep descr
descr:        Mr Jaime Lett
descr:        ADSL
descr:        Zen Internet Ltd
(although i called that straight from console, the output will be the same in the result files)
« Last Edit: 30 July 2008, 11:41:36 by PaulW »
Humbugs...
« Reply #3 on: 30 July 2008, 11:40:53 »
cheers, that looks like a neat way to do it.
Might have to put the sleep in there, most of our boxes are blacklisted from whois  ::)
ians
  • Reading
« Reply #4 on: 30 July 2008, 11:40:57 »
I think we need a foreign language sub forum ;)
PaulW
« Reply #5 on: 30 July 2008, 11:42:17 »
Humbugs...
« Reply #6 on: 30 July 2008, 11:44:50 »
You mean a superior language sub forum?  ;)  ;D
ians
  • Reading
« Reply #7 on: 30 July 2008, 11:54:05 »
I can think of a number of adjectives but superior is not one of them ;) ;D
