Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: NCDC 2015 questions.  (Read 36033 times)
Re: NCDC 2015 questions.
« Reply #15 on: 20 December 2016, 18:05:16 »
I suppose it could go pete tong tomorrow, or last for years ?
You could say that for one not exhibiting any issues.
Seems pricey for one with such a fault to me.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #16 on: 20 December 2016, 18:08:56 »
Cheers. May try and  negotiate on the price.  :y
« Reply #17 on: 20 December 2016, 18:09:37 »
removed from my Vauxhall Omega before selling
You sure it was from "my" Omega? Feedback suggests he was into Astras :-\
Migv6 le Frog Fan
« Reply #18 on: 20 December 2016, 18:19:18 »
Yeh, I noticed that too. Doesn't really matter though if it works. Depends how long it works for I suppose.  ;D
If I buy it, I will keep my old 2013 / GID so I can replace it if it fails.
    • 530D M Sport, 330i Coupe
« Reply #19 on: 20 December 2016, 18:41:49 »
So the repeat and info buttons are replaced by SOS and OnStar buttons ?
Don't remember using the repeat and info buttons on mine, so probably wont miss them.  :D
...and TP, AS, Home etc.
« Reply #20 on: 20 December 2016, 18:42:54 »
You could still get the Sharp LQ panel from the States the last time I checked.
powerslinky
« Reply #21 on: 20 December 2016, 21:03:32 »
Seems a bit steep to me  . .bearing in mind it has that screen fault  . . . .  IMO all of these units are getting well past there best .
So "you pays your money and takes your chance" as they say   :-\ :-\  bit of negotiation ;) ;) on the price maybe Albs
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #22 on: 21 December 2016, 00:50:51 »
Its a NCDC 2015 / CID without the telematics unit. Will it work ok, effectively just like a 2013, without the telematics unit ?
Ive had one of them with a missing telematics, did work, but this one kept bleeping and displaying Safe Mode at me when it was used only in CD or Nav operation, other than that was fine.
zirk
  • Epping Forest
« Reply #23 on: 21 December 2016, 01:05:47 »
Yep, came from an Omega. Will double check about the Bose though, as knowing my luck it would be the only non Bose one ever made. ;D
Do you have an opinion on the fine blue line that runs down the screen ?
Towards of the Omega life they were knocking them out in 2.6 and 3.2 MV6's (non Bose), most were 2013 but Ive come across a one or two 2015 with Telematics on the MV6's.
As said, not a problem to configure either way but again your need the original Code. If its from a Vectra or Astra its probably game over tbh.
Personally if it has screen faults, and or comes without the original Code Pass, I would hold out a bit longer for another one to come up, unless youve got an open budget for possible future fixes.
Migv6 le Frog Fan
« Reply #24 on: 21 December 2016, 07:18:04 »
They don't seem to come up very often, and 5 years ago were selling for £400+ second hand.
I have access to more electronic expertise than you can shake a stick at, but if replacement parts are scarce, then that may not be much use.
Im not going to rush into buying. Will ponder it for at least a few days. I think the price may be the deciding factor.
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #25 on: 21 December 2016, 08:24:05 »
Is there a fix for this, mine does the same...
« Reply #26 on: 21 December 2016, 13:45:53 »
Assuming you know the codes, as chat with a tech2 sorts it...
Migv6 le Frog Fan
« Reply #27 on: 30 December 2016, 23:04:30 »
Just want to recap/ refresh my memory on this before taking the plunge. If I swap it for my 2013 / GID, it will be straightforward, plug & play, yes ?
The radio / CD changer / on screen info regarding the car will all work ok ? Only thing really missing will be the phone functions, due to the lack of telematics a 2015 would normally come with ?
Are all my assumptions correct ?
« Reply #28 on: 31 December 2016, 08:54:50 »
Yes, but ideally you could do with the car code just in case.
Migv6 le Frog Fan
« Reply #29 on: 31 December 2016, 12:37:21 »
Thanks Rob.  :y Code for the unit isn't available unfortunately. I assume its a different thing to the car pass ?
Pages: 1 [2] 3 4 5 6 7   Go Up
