Author Topic: Car lock  (Read 5819 times)
gbh
  • forest of dean
    • omega cdx 2.6
Car lock
« on: 26 December 2016, 12:46:24 »
Hi all,I've been away for almost 3 months and just went to open the omega but the battery is probably flatter than a pancake and the door won't unlock with the key.It turns to the left freely but to the right its tight any ideas?I didn't want to put too much pressure on the key.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Car lock
« Reply #1 on: 26 December 2016, 12:58:02 »
You need to put a lot of pressure on the key to get it to unlock. A squirt of WD40 in the lock might make it a little easier ?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Car lock
« Reply #2 on: 26 December 2016, 16:05:22 »
Spare battery attached via jump leads - positive lead onto starter connection, earth to a good clean earth point.
 Make sure the connections are clean :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Car lock
« Reply #3 on: 26 December 2016, 16:09:02 »
Insulate everything else. A few winds of tape is enough.
gbh
  • forest of dean
    • omega cdx 2.6
Re: Car lock
« Reply #4 on: 26 December 2016, 16:54:16 »
Sorry i think you lost me with the battery,do you mean after i open door or before?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Car lock
« Reply #5 on: 26 December 2016, 17:05:28 »
The alternator has a big fat cable which goes to the battery terminal but it is VERY EASY to short out to earth and you end up doing a bit of impromptu spot welding  :-X :-X :-X
In other words, if your very carful, you can get enough juice to the circuit to open the doors  :y :y
If not, carry on with the key in the lock  ;)
I little idea for you if this may happen again ..............
Once your under the bonnet, take a couple of fly leads off the positive and negative terminals.
Mumeyfy them in tape and leave then under the car, behind the fog light so you can get 12 volts to the car if you are in the shit again  :y
gbh
  • forest of dean
    • omega cdx 2.6
Re: Car lock
« Reply #6 on: 26 December 2016, 17:10:37 »
Ah i see it, but it must be very difficult to get to unless you're over a pit?
Re: Car lock
« Reply #7 on: 26 December 2016, 17:26:29 »
Turn the key as far to the right as humanly possible. Then keep turning it so far that you think the key might snap. Then add a quarter turn.
Should now be unlocked ;)
Note that the button might not pop up, but you will feel the lock release...
gbh
  • forest of dean
    • omega cdx 2.6
Re: Car lock
« Reply #8 on: 26 December 2016, 17:33:46 »
OK will give a try in the morning.Many thanks :y
Re: Car lock
« Reply #9 on: 26 December 2016, 18:53:23 »
and the lesson learned is ...... use your manual key every now & then in the door ... use it or loose it.
As DG says, it should open with the key, though on one occasion my car refused point blank to let me in with the key, so I opened the boot (MFL) and powered the car up enough via the boot light to trigger the central locking via the fob
gbh
  • forest of dean
    • omega cdx 2.6
Re: Car lock
« Reply #10 on: 26 December 2016, 19:06:43 »
The key has always worked fine but the battery has never been this flat because the car has always been in use.I didn't want to break anything on my 2nd day back so here seemed a very good place to start as the advise given is invaluable to those of us less knowlegeable but learning. Many thanks to all
  • Auckland
    • Mazda MPV
Re: Car lock
« Reply #11 on: 26 December 2016, 19:43:33 »
My Elite's battery was flatter than a flat thing a few weeks ago.
I have read repeatedly on here about how you have to apply extreme force to manually unlock the door so I had a go but couldn't bring myself to apply that much force and gave up.
10 minutes later I tried again but gently jiggled  the key until the tumblers fell into place and the key then turned easy as anything
  • Chatham, Kent
Re: Car lock
« Reply #12 on: 26 December 2016, 20:03:32 »
Absolutely, that can't be stressed enough.
And if you're stupid enough to own a Renault, ensure that you use all of the remote keys occasionally. If you only have one, then sooner or later you WILL have problems.
Re: Car lock
« Reply #13 on: 26 December 2016, 20:06:30 »
And if you're stupid enough to own a Renault, .....
surely no one is that stupid ......  ??? ;) ;)  :y
  • Chatham, Kent
Re: Car lock
« Reply #14 on: 26 December 2016, 20:09:43 »
Stupid people are everywhere.
So are Renaults.
And while correlation is not necessarily causation, it's an entirely reasonable assumption in this case.
