Author Topic: Mis-firing following crank sensor replacement  (Read 3282 times)
PapaRomeo
  • West London
    • 2.5 CD Estate
« on: 30 December 2016, 13:38:16 »
I own an Omega 2.5 CD Estate (manual/petrol), first registered in January 1997, and which I have had since it was about 18 months/30k old.
It's been well maintained over the years by a first class private mechanic (who hates the car with a passion, takes it personally when there is a problem and is very proud of her when she purrs after a service!) I'm not enough of a petrol head to want to do the work myself, although don't have an aversion to getting my hands dirty, I just know my limits; but I have learned a lot about this car and its predecessor (a Ford Escort) while he has been working on them.
Back in September I noted that she was no longer starting on the button, which then morphed into not starting at all and a couple of homestart visits from the AA who diagnosed problems with the fuel pump relays. New relays didn't fix it. A mate of the mechanic who does electrics actually came out to fix the problem I had with the electric windows and ended up looking into the starting issue. He fitted a switch to manually fire the fuel pump as his modern diagnostics could only find an issue with the earthing from the ECU to the relays.
All this took time to occur, partly because the car is mostly driven only one day a week at the moment.
Finally the mechanic unearthed his ancient diagnostic computer and diagnosed the crank sensor.
As usual Vauxhall gave him the wrong part, initially supplying him with a sensor with the "square" connector (actually, over the years my car has never taken the parts suggested by the reg/vin #s), then a Siemens sensor. The mechanic took a Bosch sensor with an oval connector off the car, so - having read the guide on here - I quoted him the part number for the facelift models and that's what he fitted (and it matches the part # on the sensor he removed) - except that he tells me that the new sensor was not labelled Bosch; there was no apparent manufacturer labelling to it at all.
The day he fitted it he had the engine running like a dream again and starting instantaneously.
The mechanic is based close to my parent's house and does the work on your drive, so he does the work at their house. Unfortunately it was two days later when I got the train over to pick the car up and as soon as I started it I noticed three things.
1) The dashboard display, which has been steadily losing pixels over the years, was much improved (although that didn't last!)
2) Although the engine fired up immediately, there was a whistle or a whine to be heard as it did so
3) The engine was wrong from the moment it fired up (that was where my heart sank)
I had to find the mechanic at that day's job to pay him and when I pulled up his heart sank too as he thought it sounded like my car, but the engine was misfiring.
When he changed the crank sensor (he changed both, I forget what the other one is called, off hand) the engine was drenched in condensation - an issue he said he'd had with several cars that week. Hence he thought that maybe some moisture had got into the leads/plugs. A week or so later he changed the leads and coil pack and finally the plugs: still no improvement. Plus I think the misfiring has finished off the exhaust which will only make things worse with the engine management.
The mechanic wondered if he'd managed not to reconnect one or more of the vacuum pipes properly, but he was not having a good day the day he changed the coil pack, leads, etc as he wasn't well, and was very demoralised that it was running no better at the end. As he'd pushed out other work to fit me in I tried to take the pressure off by leaving any further work into January. I don't need to drive it a great deal at the moment (although I DO need a reliable, working car). It's a ~30 mile motorway drive between home and my mother's place - and the car will do it if necessary (in fact I think it runs best at 80 at the moment!) But I did notice driving home that I can't get hot air down to the footwells at the moment which, I believe, is a pipe connection issue (and it would be terrific if this was the answer to it all).
The whistle/whine can only be heard inside the cab, with the door shut - presumably the engine noise masks it outside the car - and does seem to track the throttle.
To me, it sounds horribly as if the ECU is not mating with the new sensor, based on the FAQs to be found here on the subject.
Anyone got any insight to offer?
Thanks
ted_one
Re: Mis-firing following crank sensor replacement
« Reply #1 on: 30 December 2016, 16:11:32 »
If you can't resolve it here,which is unlikely, then the person you will possibly need to contact is Serek who is a member on here and owns SOS Automotive up in Huntingdon, not sure which part of London you are in but if you can get it there he will make you a happy bunny.Just one question...did your mechanic used genuine or aftermarket parts? as the Omega doesn't take to kindly to cheapo unnamed/ aftermarket products :'(
PapaRomeo
  • West London
    • 2.5 CD Estate
« Reply #2 on: 30 December 2016, 17:46:55 »
The replacement sensor was supplied by a Vauxhall dealer and should be a genuine Vauxhall part.
We had to wait nearly a week - twice - for the part to come over from Germany, and the dealer wanted to charge him for re-stocking on the incorrect sensor that they supplied to him originally!  ::)
Zirfeld
  • Lahr/Germany
    • 2.0/16V Saloon+Estate
« Reply #3 on: 30 December 2016, 17:54:30 »
Hi PapaRomeo
As nitro wrote, never use aftermarket cam or crank senors on a Omega, only Bosch, Siemens or Hella origin parts.
First of all, read out the error code. Most sensor faults are detected and archived there. If no fault is detected, I think 3 faults are possible:
Blow by system
"Abgasrueckfuerung" sorry ,I do not know the correct English word for that
Fuel pressure
Rolf
I am not forced to drive an old Omega. I simply like it.
ted_one
« Reply #4 on: 30 December 2016, 18:10:54 »
Do you have a code reader, or access to one? Looking at the year of the car I'm not sure wether mine will be of any use...perhaps someone can confirm that a '97 car can be 'plugged in' :-\  Where abouts in West London are you as there may well be a member near you who can help.
« Last Edit: 30 December 2016, 18:23:21 by nitro »
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #5 on: 30 December 2016, 18:55:30 »
Should be able to paper clip test a 2.5.  The unlabelled crank sensor now gives us a bit of an unknown. Does it hold vacuum, after it has been running you should be able to leave it for a few minutes with the engine off, then pull off a vac pipe and hear a distinctive hiss. If a pipe has been left off this could explain the whistle. Has the plenum been off at all as this will give us an idea of what has been removed.
Any water or oil in the plug wells, although the mechanic would have spotted that when he changed the plugs?
PapaRomeo
  • West London
    • 2.5 CD Estate
« Reply #6 on: 30 December 2016, 21:03:09 »
If you are Reading, as your profile says, Nitro, I am about 10 miles from you.  ;D
The mechanic has a reader that connects to my car, (the old one from the bottom of his van, that he didn't bother to throw out!), he got a code 19 originally before changing the sensors, but wasn't getting any error codes when he checked it last time he worked on it.
He's convinced that it is something other than the crank sensor - and he is usually right - he's the primary reason that the car has done nearly 200K miles and is (well it was before this) still going strong.
It's just that reading the FAQ's here about changing the sensors, and being an electronic engineer myself, I know that these things can be pernickerty. And it bothers me that the replacement part apparently wasn't Bosch branded, when it should have been. But I don't know where to look for it to see for myself what - if any - markings there are on it.
But the mechanic was having a really bad week when he last worked on it, besides not being well and pushing out a bunch of other jobs to spend 2 days working on my car in two weeks, and at the end of it she still wasn't purring for him so he was very demoralised.
He's a good man and would have pushed himself too hard trying to get it fixed before Christmas, but he and his health are more valuable to me than having the car fixed immediately.
I might be expecting too much here, I know a fair bit of what he has done to the car recently, but not enough to answer all the questions, so this could end up as a three way conversation, needing the involvement of the mechanic!
  • Auckland
    • Mazda MPV
« Reply #7 on: 30 December 2016, 21:21:59 »
If you can hear a whistle and there are problems with your heating controls then there is a good chance that one of the vacuum pipes has been disturbed or even snapped off behind the engine.
« Reply #8 on: 31 December 2016, 10:44:36 »
Nitro - a 1997 car is not OBDII compliant
« Reply #9 on: 31 December 2016, 10:45:41 »
A bit air/vac leak can upset the trims causing misfire. Also misfires with no associated codes can be HT
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #10 on: 31 December 2016, 14:50:08 »
Hi Paparomeo, welcome to the Forum. I did enjoy your splendid post about your 20 year and 200Km old Omega 2.5 petrol manual estate. I am sure there is little wrong with it that this forum cannot diagnose.
You and your mechanic must know it pretty well after 18 years. I note he has changed plugs, leads, coil pack and crank sensor, to little effect. I presume over the years he has serviced it, and changed cambelts, plugs, oil, etc. In changing the plugs he would have discovered oil or water in the plug holes if there, and rectified accordingly.
 I have known a defective new Vx dealer supplied crank sensor. Test is to borrow a known good one and try it.
Was the engine management light on? If not, there will be no stored codes. I have changed 4 failed crank sensors on 2.5 Omegas, none lit the EML
The hissing, lack of power but good at 80 suggest plenum dual ram not operating due to vacuum leak.
Trouble with good advice is that as you are not handy with spanners your mechanic will have to act upon it. You could do worse than seek the aid of a local travelling Omega wizard, Doctor Gollum and Nick W spring to mind
I understa
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #11 on: 07 January 2017, 10:54:18 »
that is exactly what happened prior to my crank sensor going - the odd occasion of car not starting on very first turn.  if you are worried about the replacement sensor i suggest you simply replace it again -  it will be very easy the second time as the cable is now re-routed and they are not too expensive - my £27 delphi branded one has been fine for 10k miles and over a year so far.
after that if not fixed you will need to start looking at the other things that have been done eg fitting new fuel pump relays perhaps
