Author Topic: Wet Concrete on paint?  (Read 7386 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Wet Concrete on paint?
« Reply #15 on: 06 January 2017, 20:24:20 »
When I had the convertible I was convinced that one day I would be shat on but thankfully it never happened.  ;D
« Reply #16 on: 06 January 2017, 20:27:19 »
Mrs TB once opened sunroof whilst reversing off driveway...   ...what a shot!
She wasn't happy, mind...
YZ250
« Reply #17 on: 06 January 2017, 20:30:42 »
 ;D ;D
They definitely circle around up there and pick a target. Must be like a game to them.  ;D
« Reply #18 on: 06 January 2017, 20:34:40 »
 ;D ;D
She felt like a WWII Dresden resident once in Bowness.  Clearly she attracts it :P.  Naturally, I didn't laugh. Much.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #19 on: 07 January 2017, 00:53:18 »
I think it's concreate, it appeared I *think* after I parked in an underground car park.
You say you found it after you parked in an underground car park?
Most car parks are built of concrete, and I think what you have on your wing is the result of water dripping from cracks in the concrete. The water drips are likely to have a small lime content in them, and the marks left are sometimes refered to as 'lime weeping' or 'lime leeching'. Going back to my schooldays, this is how stalactites are formed over many years. If you have ever gone into underground caves, you can often see long white 'spikes' called stalactites hanging from the top of the cave where water has dripped which make a 'stalactite' on the ground forming where the water drips. The two eventually meet.
If this what you have on your wing, which I think is a strong possibility, then it needs to be removed asap, but from the length of time you say it has been there, I would say it will have had the same effect as leaving bird shite on your paintwork, and will have eaten into the surface of the paint and will be a swine to remove.
What to use, I wouldn't like to say.
However, if the mark left is similar to that from bird shite, there is a technique where they can be removed by the careful use of a hot air gun which in effect softens / melts the lacquer slightly causing it to 'run' filling the affected area laquer. No amount of cutting will do it. There are YouTube clips that show how it's done.
You need to be a braver man than me though!
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #20 on: 07 January 2017, 00:58:59 »
If it is limescale residue you could try some limescale remover, I`ve used Limelite before on efflorescence with reasonable results on some internal polished blocks where brick acid couldn`t be used.
You can get limelite from supermarkets, green spray bottle.
« Reply #21 on: 07 January 2017, 12:23:06 »
Over the years I've had countless birds shit on my cars, from sparrows to albatross. I've sometimes cleaned it off straight away, and some times left it for weeks.
Not once has it damaged the paintwork.
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #22 on: 08 January 2017, 12:04:05 »
Could just use some bird shit remover you can buy from Halfords and the like....
I also have never had any problems with leaving bird shit on my cars paintwork for weeks and its never marked the paintwork....
D.I.L.L.I.G.A.F...
« Reply #23 on: 08 January 2017, 22:08:15 »
Thanks. Can only think it was then, might have been another time though.  :-\
Same, never had any problems. Reaching point of can't be bothered with the 3.2 though, rarely wash it. The multi-ram is broken, its hugely over-due on it's cambelt and now it's got some crap on the body work I can't remove.
Might try the hot towel trick though.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #24 on: 08 January 2017, 23:07:20 »
Id try clay (Meguiars kit in Halfords is decent, Bilt Hamber Autoclay from the web is better). Thats speaking as a detailer :y
