Author Topic: Disappearing water  (Read 1875 times)
ShazC
  • Shropshire
    • Omega 2.2 51 reg
Disappearing water
« on: 06 January 2017, 19:24:05 »
Hi there
Can anybody help us please our Ming has started to use / loose water about 1-2 litres per week heater has been fine but only aired now heater gauge hardly moves now last two days !  No water leaks, no loss of power , no miss beats of engine , no gunk around oil or expansion cap!  Any clues ? Is this possibly head ?  The heater has been hot until 2-3 days ago .... thanks
Re: Disappearing water
« Reply #1 on: 06 January 2017, 19:28:03 »
Classic Hbv failure. Try it with both temps set to Lo, fan on minimum and wrap up warm. No further coolant loss = Hbv failure as number one likeliest issue...
Unless drivers foot well carpet sodden and a faint smell of coolant in the cabin, which means heater matrix failure
ShazC
  • Shropshire
    • Omega 2.2 51 reg
« Reply #2 on: 06 January 2017, 19:52:46 »
Ok thanks my husband says it has been wet around that h b v so put another clip on pipe and still using water.  Can you get this part if so how much and where from thanks
« Reply #3 on: 06 January 2017, 20:17:28 »
Cant remember if its same part as the V6 one, but if so, about £15+VAT from dealer
ShazC
  • Shropshire
    • Omega 2.2 51 reg
« Reply #4 on: 06 January 2017, 20:26:16 »
Ok thank you we will test tomoz with the heater on low and see how we go thanks for your help and will let you know how we get on
