This might be of interest, but it won't go cheap...
Started by Doctor Gollum, 17 January 2017, 08:44:16
If it runs fine on petrol but misfires on LPG that is quite likely to be caused by worn out spark plugs - LPG needs a higher voltage to strike a spark and also burns hotter and causes faster plug erosion than petrol.
Quote from: Andy H on 20 January 2017, 21:14:27
Quite possibly. IME Iridium plugs are of no benefit with LPG  :-\
Quote from: Lazydocker on 20 January 2017, 22:20:21
.. and standard plugs come out looking like new after 40k miles... Now, if the LPG system is running lean... ::)
X30XE
There was some chatter on the Saab forum about iridium plugs not doing the DIS pack any good. (Something to do with poor electrical conductivity in trade off for better longevity).  Don't know if this applies to other GM cars too.
Omegatitis : [in remission]
I would like to hear the physics behind that theory  :y
Probably be some beer influenced man maths involved :D
Migv6 le Frog Fan
If the "number plate is worth £500" why doesn`t he sell that??????????
X30XE
Quote from: Marks DTM Calib on 22 January 2017, 20:02:19
I suspect it might be people getting confused between damage caused by not fitting resistive plugs tbh.  Some of them are a bit... yeeeehaw  :P
X30XE
Quote from: RobG on 22 January 2017, 21:38:18
Cos it takes years to sell a private plate at it's full value.  Unless it's incredibly rare and desirable.
Fraggles Rock
Quote from: X30XE on 22 January 2017, 22:33:02
MoT history looks ok, couple of trackrod ends and donut bushes and that's... suggests that it's been relatively looked after over the years :-\
Quote from: Fraggles Rock on 23 January 2017, 11:28:27
Pictures tell different story, seller needs to get some lessons on using a camera  ;D
Clearly been stood a while ;)
Rust spot on wing could either be a poor, older repair or storage damage...
Quote from: X30XE on 22 January 2017, 22:31:43
Well all an iridium plug offers you is the ability to run at higher combustion temperatures.
If you consider how a coil works then there is pretty much nothing it can do to the coil pack to damage in fact, pretty much every coil pack failure we see is due to the core failing (corrosion or separation of the laminations) resulting in less energy being stored and a lower power spark.
