iPhone 5s
Started by Shackeng, 26 January 2017, 13:42:43
Shackeng
I forgot to mention that although my landline was down for a few days, for the first two days, the broadband worked normally. ??? ??? ??? The Openreach guy said that the internet only required 1 line. ??? ??? ???
I find that hard to believe. Perhaps it required a lower voltage or some such. Any ideas. :-\ :-\ :-\
A bad connection near the CPE can stop phone working, and DSL still works - though 9 times out of 10, DSL will drop when you pick up the phone in this scenario.
Shackeng
Quote from: TheBoy on 29 January 2017, 18:06:32
Didn't happen with me, but I guess it was to do with 40Yr old internal cable, now replaced, and a poor connection at the green cabinet which they discovered. Interestingly, I measured the resistance of known good, strands of the old cable, against the new one, and, if I read my meter correctly, the old was 4 ohms, and the new 2 ohms, presumably due better quality materials used. :y
Due to the nature of the signals, impedance is more useful than resistance...   ...but, yes, sounds like the old cable was , errr, old ;D
The cable to my BT box is ancient. It disappears behind the door frame and reappears from behind the skirting about 5 metres away.
Quote from: STEMO on 29 January 2017, 20:47:49
Sounds similar to ours before the dog chewed through it ;D
Referring back to a previous conversation TB, we no longer have a non cordless phone in the house, so will effect that what which you suggested ;)
