Author Topic: High hydrocarbons and carbon monoxide values  (Read 2612 times)
Smolle94
  • Stockholm, sweden
    • Omega 2.0 16v -98
« on: 27 January 2017, 17:54:01 »
Hello,
Omega 2.0 16v ecotech -98
Bought a omega recently and had mot yesterday.
Co 1,6 (0,5)
Co 2500rpm 1,2 (0,3)
Hc 175 (100)
Oxygen/lambda sensor 1,02(0,97-1,03
(Values in parantheses)
Chazza12
  • south yorkshire
    • 1996 2.0 16v CD estate
Re: High hydrocarbons and carbon monoxide values
« Reply #1 on: 27 January 2017, 20:33:36 »
when was the cat last changed ? any engine problems ?
« Reply #2 on: 28 January 2017, 13:27:54 »
Check for misfires first. If all is good, give it a good service, some good fuel (or a decent additive) and an Italian tune up :D
« Reply #3 on: 28 January 2017, 20:58:07 »
Also check it's getting up to normal running temperature. :y
Smolle94
  • Stockholm, sweden
    • Omega 2.0 16v -98
« Reply #4 on: 29 January 2017, 18:29:41 »
It's running at about 90* but have some problem to keep the heat up on the highway.
When I "floor it" it smells like oil in the car.
Did a service yesterday. No difference...
I'll have no idé when the cat was change.
Italian tune up?
Sorry if bad english, not my first language :)
« Reply #5 on: 29 January 2017, 18:37:33 »
Fill it with shell optimax and two cans of fuel treatment, Wynns works well if available there...
Then drive it hard until the fuel is gone...
Repeat then retest :y
« Reply #6 on: 29 January 2017, 19:40:16 »
Sorry, didn't spot you were from Sweden.
Full with premium fuel, add some quality fuel treatment and then take it for a good, hard drive.
« Reply #7 on: 29 January 2017, 23:51:17 »
I don't suppose it's suffering from a cracked exhaust manifold as many of the 4 pots do? Any sign of an exhaust blow from it when started from cold?
Smolle94
  • Stockholm, sweden
    • Omega 2.0 16v -98
« Reply #8 on: 02 February 2017, 10:57:07 »
Didn't find any cracks in the exhaust, but did find some oil in the "pipe" thats closet to the cabin.
I think one or two of the valve "stering" is broken.  :(
So the engine will find a new life in the scrapyard.
A new hart will be donated from a Saab b204/205 hybrid  :)
The gearbox will be changed to a r25/28 or a r28
Do you recommend any differential(LSD)
Thanks for the help  :y
Page created in 0.031 seconds with 20 queries.
