BMW 530d Overhaul Thread - With Pictures
Started by JamesV6CDX, 27 January 2017, 21:35:32
X30XE
Omegatitis : [in remission]
Quote from: JamesV6CDX on 09 February 2017, 19:09:23
Not too much work lately. Been busy with medical appointments and such and the weather has been grim.
I noticed that the no5 glow plug was broken off (not my doing) - that'll account for why I've always had a "glow device" fault code, then!
This has confirmed my decision to pull the head off, having got this far, as I will also sort this out at the same time and fit a set of 6 new glow plugs.
I bought a locking kit for this engine. It's simply a case of locking the flywheel at TDC using a pin (I say simply, it's a bastard to locate it!) - and then fitting a tool over the cams to which must sit flush with the head. You can then remove the top chain guide, rotate the exhaust camshaft carefully clockwise a small amount to release tension, and insert another pin into the tensioner in order to lock it off.
Here we are with the sprockets off, and camshafts out:
No time for that, James, get on with the car.  ;D
Quote from: X30XE on 10 February 2017, 18:27:25
Get some wd40 on those cams  :P
I'll give them a good clean up over the weekend :y
STEMO, sometimes, a man has needs  ;D
Quote from: JamesV6CDX on 10 February 2017, 18:31:47
It isn't a clean they need - they need industrial strength rust protection.
Are those bearing caps numbered? or otherwise marked so that they go back in their original locations?
Quote from: Andy H on 10 February 2017, 19:49:02
Of course
Caps are all marked A for Exhaust, and E for Inlet, and number 1 onwards, from the timing chain end.
It's essential they go back in their original places / rotation
You say industrial rust protection - what you can see, wipes off with an oily rag. A quick clean up and they will be fine, especially once back in action.
I am however going to paint them in clean engine oil or similar to protect them, whilst the car is apart.
Apparently this stuff is ideal for rust protection, James: http://www.ebay.co.uk/itm/112175365860
Haven't tried it (yet) myself but intend to get some for the lathes that are sat out in the garage.
Best thing to do with cams while they're out of the car is oil / WD40 them and wrap them in greaseproof paper or cling film. You don't want surface rust to damage the thin hardened surface as they will then wear rapidly.
Thanks chaps will do :y
Broken off glow plug is proving a mare  >:(
Get it running quickly James, as there's talk of a generous scrappage scheme for older diesels!  :)
Quote from: Sir Tigger QC on 13 February 2017, 16:32:09
They can prise the keys to my 20mpg Omega, and sooty old straight 6 diesel, from my cold dead fingers  ;D >:(
Went to machine shop with the head today.
£250 to extract the glow plugs with 80% success rate. One came out ok. One was already broken clean off before I touched it. And the other 4 just span by hand and the hex nuts broken from the plug at the base
Someone's been in there before :(
Alternatively found a head with 30day guarantee from a low mileage 2002 model for £120  :-\
Quote from: Doctor Gollum on 13 February 2017, 17:40:36
Only one outcome there then... ;)
Yeah scrappage!  :D
Given that I paid £900 for my 530d, I'm going to be watching developments on any scrappage scheme for old diesels with interest!  :y
Other than that though I've no plans to get rid. Which is why I'm following Jame's thread with interest!  :y
