Author Topic: Exhaust. car on ramps and stands  (Read 4891 times)
lesask
  • london
    • omega 2.6cdx
« on: 05 February 2017, 10:19:46 »
hi there readers. Ok I want to change my exhaust system, I have high up ramps but whichever way I do the car the other way round is far too low, i cannot do this job on my driveway like this. Therefore I need to borrow a pit, (if anyone has one Id be much obliged and clearly Id pay you for its use) or could I put one end of my car on the ramps and then jack the other end up completely off the ground and use stands. is this ok? Leslie
Re: Exhaust. car on ramps and stands
« Reply #1 on: 05 February 2017, 10:24:25 »
That's how every body else does it ;)
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
« Reply #2 on: 05 February 2017, 11:16:01 »
Without question put the rear wheels on the ramps and jack the front end up - not the other way round. Otherwise there's no way of applying the handbrake / leaving it in park to prevent any vehicle movement. I wouldn't like a heavy Omega to decide to roll off ramps whilst I was under it.
« Last Edit: 05 February 2017, 11:18:12 by johnnydog »
flyer 0712
« Reply #3 on: 05 February 2017, 11:19:43 »
As said.(thats the way to do it) pieces of eight..pieces of eight... :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 05 February 2017, 11:34:10 »
If you're only doing the system from the cats back, there's no need to jack the front. That only becomes necessary if you have to drill the flange bolts.
I did mine on my own, in the street with just the rear lifted in under an hour.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #5 on: 05 February 2017, 11:42:41 »
Take care. Axle stands, ramps and jacks can all fall over sideways given a big enough heave.
« Reply #6 on: 05 February 2017, 12:41:35 »
Had to take my exhaust off yesterday, with the help of that nice Mr Gixer fella, to swap over a subframe.
As per always, jacked the arse high in the air, undid bolts joining to cat section, removed off hangers, pulled out.  Refit is reverse.
« Reply #7 on: 05 February 2017, 13:17:54 »
Done mine on drive too, back end in the air and no probs  :y
« Reply #8 on: 05 February 2017, 14:00:32 »
Just be cautious if you need to get the grinder out :-X
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #9 on: 05 February 2017, 14:52:40 »
If you jack the Axle rather than the Car, your get a higher lift at the back, I normally then lower the rear wheels, or just above,  on to a set of spare wheels I have kicking around, that way if something does slip, or let go, it lands on the wheels rather than the ground.  ;)
« Reply #10 on: 05 February 2017, 14:54:48 »
Do NOT jack the diff though as that's what kills the mounts...
lesask
  • london
    • omega 2.6cdx
« Reply #11 on: 05 February 2017, 20:14:32 »
many thanks. thats what im going to try then, rear wheels on ramps and stands on front end. anyone got a pit I can borrow? I will pay
zirk
  • Epping Forest
« Reply #12 on: 05 February 2017, 22:32:39 »
How you going to borrow a pit, cant exactly post it. ;D
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #13 on: 05 February 2017, 22:55:38 »
could borrow another 2 ramps instead ???  not sure how to get 2 behind the front wheels though :-[.
lesask
  • london
    • omega 2.6cdx
« Reply #14 on: 06 February 2017, 08:02:09 »
lol, i know i cant borrow a pit like that, i mean if someone has a pit then i drive over and use it, i do all the work on my car and i pay someone for the use of it.
