Author Topic: bolts sheared off. scrap car  (Read 6303 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: bolts sheared off. scrap car
« Reply #15 on: 06 February 2017, 19:17:50 »
that said, I do normally retap mine. Anal, I know.
Not anal .... just correct  ;) that's what I did when I did  mine
And use proper exhaust bolts, and I coppaslip the thread.
Is a 'proper' exhaust bolt stainless? ::)  :y
no their mild steel with copper nuts.  even on a full stainless RR system.
mine are m8, mild steel, washers n nuts, flanges drilled with 8 drill and wiggled about,  :y
Hoof'land storeman.
« Reply #16 on: 06 February 2017, 19:21:56 »
Mine were stainless on a full stainless system with s/s washers ...... courtesy of the stores at my previous place of work  :D ;)
biggriffin
« Reply #17 on: 06 February 2017, 19:26:38 »
stainless bolts actually cost no more than mild when bought in bulk, cheapest's places to buy stainless bolts is Aberdeen, GT Yarmouth, and Lancaster, due to the offshore industry.  :y
Hoof'land storeman.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #18 on: 06 February 2017, 21:24:17 »
My solution is not to break them off in the first place. I achieve this by first heating the flange and bolt to red heat with a blow torch. I allow it to cool, spray with penetrating oil, then gingerly apply torque with a spanner. If it moves a bit, and it usually does, I spray with more oil and turn it back and forth a bit to work the oil into it. Then I undo it a bit more, more oil, more to and fro, until it turns freely. Then I fully unscrew it, discard the screw, and clean the thread with a tap or better a thread cleaner. I reassemble with a new screw and copper ease.
Having broken off many in the past, I find this exercise most satisfying, and have not broken one off since I adopted this technique. It helps having a pit.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #19 on: 07 February 2017, 02:05:36 »
cobalt drills good choice.  If they are a decent make they probably will be split points.  BUT cobalt drill bits are very brittle - do not apply any sideways force whatsoever and very little downforce.  it will be a much bigger pain if they snap off in the holes - you can't drill out a stuck cobalt drill bit.
I vaguely remember using an angle grinder with thin disc to cut the bolts first.
