Author Topic: Smart battery charger...  (Read 5239 times)
Re: Smart battery charger...
« Reply #15 on: 06 February 2017, 19:44:26 »
Aldi and Lidl usually have a three year warranty
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #16 on: 06 February 2017, 19:45:07 »
Most "smart" (hate that term!) chargers pulse-charge the battery so that they can check the state of charge between pulses, and that is likely to upset the various ECUs in the car, necessitating the removal of the battery connections to charge it in isolation.
Not a big problem, just a chore, especially as it requires you to recode the radio, etc., afterwards. I use a 13.8 volt regulated power supply: I KNOW that it will not bulk charge the battery, KW, but it ensures a successful start and the alternator does the rest of the job!
Ron.
« Reply #17 on: 06 February 2017, 19:46:13 »
Ron.
Many (but not all) allow charging of battery on car.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #18 on: 06 February 2017, 20:00:30 »
Correct :y
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #19 on: 07 February 2017, 02:18:34 »
had a fancy Ring handbag shape one, lots of nice features like 'revive', lasted year and one month  >:(
i've had 3 halfords fully automatic chargers for 15 years all still going strong.  however they don't look like the latest halfords one - which looks handbag shaped and suspiciously like a re-branded Ring.
also have a sealey smart inverter charger for 9 years that is still good. watch out they do two similar models one is not suitable for sealed bats.  this one does sealed:
« Last Edit: 07 February 2017, 02:24:36 by migmog »
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #20 on: 07 February 2017, 03:54:08 »
Either Lidl or Aldi were selling them again recently
Most shops don't quibble much these days.
Most people who work in shops want the easy life.
They really don't care as it will all be on sale or return. Been there done that with various UK and ROW multiples and it is part of their standard T & C's if you want to do business with them. If you think that is tough, you've never dealt with US retailers, where you pay for them to stock it.
The advantage is that if you have the right product at the right price in the right place, they shift big volumes, did I mention they shift BIG volumes, although it will mostly be at very low margins, but every little helps, when it comes to annual profits.
Direct sales are always best with big margins but they will always be at very low volumes.
TD
  • Swindon
    • Nowt!
« Reply #21 on: 07 February 2017, 04:31:08 »
Bought one of these a few years ago from Lidl/Aldi (carnt remember which one) after someone posted on here about them
Its now broke  :( Turn it on and it goes into standby mode...press the button to select 12V and car battery and nothing happens, it remains in standby mode...
It was about £15 iirc....
So any suggestions for a replacement....searched Aldi/Lidl and cannot find anything similar......don't want to spend much as its for a leisure battery which I may/may not (most probable) use again....
You've got it attached to a battery yes?  Does the battery register a voltage on a DMM over ~10v? Cos if it's flat as a pancake the smart charger will just sit there like a lemon.  If this is the case try paralleling up a known good battery and see if it chooches.
Failing that give it to someone with some electrical knowledge. It's probably fixable.
Yes,  its over 12v  :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #22 on: 07 February 2017, 18:16:44 »
Are you sure its broke, the Lidl ones where not chargers but conditioners, they wouldn't charge or do anything if the Battery was flat (below 10v from memory).
