Author Topic: Problems with caravan fridge...  (Read 9628 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Problems with caravan fridge...
« Reply #15 on: 12 February 2017, 15:04:27 »
Leave it as long as you can bud  :y
What is the resistance across the elements ?
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
« Reply #16 on: 12 February 2017, 16:01:14 »
Well its gone back in, quite easily.....?
Dunno what the restistance was across the elements, I tested the power supply and didn't think of testing the elements, never thought of that coz of the rear getting warm on all three inputs....
Only thing I can do now is hope, I guess.. otherwise I'll have to save me pennies....
D.I.L.L.I.G.A.F...
minifreek
  • Wigan
« Reply #17 on: 12 February 2017, 18:40:58 »
Well its been on now for 2 1/2 hrs and there is ice cubes in the freezer compartment.... so think its fixed itself :)
Thank opps for that..... I'll sleep tonight now LOL
D.I.L.L.I.G.A.F...
« Reply #18 on: 12 February 2017, 21:15:43 »
A result then ..... & at no cost  :y
minifreek
  • Wigan
« Reply #19 on: 12 February 2017, 21:47:38 »
Yeah thankfully...
I reckon if the freezer compartments working, the fridge part is working too...
So... good result... :y
D.I.L.L.I.G.A.F...
2boxerdogs
« Reply #20 on: 12 February 2017, 21:48:37 »
That's great a cheap fix 😉
minifreek
  • Wigan
« Reply #21 on: 15 February 2017, 17:00:56 »
Just an update.... freezer compartment works wucking brilliantly, however the fridge part just doesn't seem to be getting cold....?
opps....
D.I.L.L.I.G.A.F...
hercules
  • sunnyudders
« Reply #22 on: 16 February 2017, 21:53:32 »
Daz (Hercules) is the go-to on here for vans. He doesn't get on here very often nowadays but, if you drop him a PM, I'm sure he'd try to help.
http://www.omegaowners.com/forum/index.php?action=profile;u=8247
PS, he's a big, ugly git....but he doesn't bite.  ;D
love you too baby  :-* :-* ;D
hercules
  • sunnyudders
« Reply #23 on: 16 February 2017, 21:59:53 »
chances are the outside temp was cold and the fridge was absorbing that coolness to turn its gas back to liquid therefore not cooling the compartment,i have never had to turn a fridge upside down
minifreek
  • Wigan
« Reply #24 on: 17 February 2017, 02:05:26 »
I understand what your saying about outside temps, but it isnt that cold... It worked fine last February when we was away in the tintent and there was snow on the ground...
Id have thought that if the freezer is working, the fridge part would work too, didnt think they are seperate systems...
D.I.L.L.I.G.A.F...
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #25 on: 17 February 2017, 11:39:44 »
"Id have thought that if the freezer is working, the fridge part would work too, didnt think they are seperate systems.." - exactly what I thought, too, but I didn't like to say!  :-[
Ron.
« Reply #26 on: 17 February 2017, 11:54:05 »
Ron.
They are one system .. freezer compartment cools down a lot, cold air from that drops down to cool the rest of the fridge..... no separate controls or cooling elements.
Bigron
  • Witham, Essex
« Reply #27 on: 17 February 2017, 12:02:45 »
Thanks Nige, that's exactly as I had it, but refrained from comment initially in case there was a newer system that I didn't know about and I embarrassed myself!   :-[ :-[
Ron.
« Reply #28 on: 17 February 2017, 12:12:59 »
Thought about this too late to edit my previous post ...
If the Freezer is getting really, really, cold and the rest of the fridge is not, check things like door seals / door closure as if the door is not closing properly the cold air from the freezer bit will escape and not cool the fridge .. a thermometer on the floor below the fridge door may give some indication of this ?? (cold air drops) ....
minifreek
  • Wigan
« Reply #29 on: 17 February 2017, 13:41:59 »
Thanks for the replies, I'll check the door seal... theres only 1.
I haven't got a thermometer though :(
Was going to buy 1 of those fridge thermometers that stick to the inside - they look a bit like the ones you get on a fishtank/aquarium.....
D.I.L.L.I.G.A.F...
