Author Topic: Talking of BMWs...  (Read 5653 times)
Re: Talking of BMWs...
« Reply #15 on: 15 February 2017, 16:23:01 »
It's square in the middle opposite... So I have to negotiate it which ever way I leave the drive >:(
Awaiting a call back from Sussex... Just in case it has been stolen... It appeared around 5am yesterday.
« Last Edit: 15 February 2017, 16:25:31 by Doctor Gollum »
« Reply #16 on: 15 February 2017, 16:23:41 »
Put a glossy magazine in front of each back wheel.
Hook a ratchet strap around the rear part of each wishbone.
Loop the centre of the strap around your toward.
Drag the bloody thing clear of your drive.
Problem solved.
Nice idea, just need a towbar ::)
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #17 on: 15 February 2017, 16:28:20 »
I've heard burnt out cars get removed quite quickly  ;)
Omegatitis : [in remission]
« Reply #18 on: 15 February 2017, 16:29:45 »
Bit close to the house if it goes pop. Besides it's not that sort of area ;D
X30XE
  • UK
« Reply #19 on: 15 February 2017, 16:32:52 »
You can't make an omlette...  ...end of sentence.  ;D
They let you in evidently  :D  ;)
« Reply #20 on: 15 February 2017, 16:43:03 »
Feeky chucker, been here 17 years, so just about a yokel :-P
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #21 on: 15 February 2017, 17:37:51 »
BMW - Stopped out of the blue - Completely dead -  Not even hazards - Owner walking
Not that I'm stereotyping or anything  ::)
FTFY. ;)
 :-X
Not mine, I can confirm. Although I had thought about leaving mine in the crappest part of Birmingham should I be forced to take it back. I figure it would only take 1-2nights max for nature to take its course.  :y
  • Online Online
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22 on: 15 February 2017, 18:24:21 »
Loop the centre of the strap around your tow bar.
Problem solved.
That just makes it easier. If your BMW has a fixed towing eye at the back(after 18months of not doing recovery work, I can't remember :) ) then use that - do NOT use a screw-in tow eye. If it doesn't, then a semi-trailing arm will do.
Page created in 0.013 seconds with 15 queries.
