Author Topic: Climate control - how is it controlled?  (Read 5585 times)
Boatboy
  • St Albans
« on: 16 February 2017, 13:42:48 »
Hi, talking facelift elite here.
I understand the outside temp sensor, coolant sensor and sun sensor play a part in dertimining what the cc needs to be doing, but as facelift has no sampler fan how does it get feedback to know its achieved its goals?
Question arises as today I was parked ticking over facing bright sun and feeling cold. Outside temp read 7deg, inside set to 21deg as usual and there's cold air coming through the vents. Increase the required temp and warm air follows. (Drivers side at least, passenger side is normally cold and I guess needs an upside down looking at).
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
Re: Climate control - how is it controlled?
« Reply #1 on: 16 February 2017, 14:55:36 »
Apart from the cold air in your face, could the cabin temperature otherwise have been at 21 degrees already?
Ron.
New POD
  • Miseryside
    • NEED MV6
« Reply #2 on: 16 February 2017, 20:29:10 »
I have no idea, but I can't get my feet warm.  :-[
Bigron
  • Witham, Essex
« Reply #3 on: 16 February 2017, 20:59:17 »
Just to clarify: if that nice warm sun streaming into the car was telling the sensor that you were already at 21 degrees, the CC would not feel the need to give you more warmth. The fact that you DO get warmth when you increase the setting tends to confirm this?
Ron.
Boatboy
  • St Albans
« Reply #4 on: 17 February 2017, 10:23:55 »
Thanks for the replies Big Ron - I think i'm getting the picture. There is no feedback on the facelift.
In 'Auto' the cc will operate to a certain profile based on sun, ext temp and drivers requirements with no heed to what is actually being experienced by the occupants.
If that don't suit, such as when the occupants regularly change from skinny young neice on her way to ballet to the complete Harpenden front five of twenty years ago, switch to manual control.
At least when I'm trying to fix the cold air passenger side issue I wont be looking for themistor bulbs or such like to clean :y
Steve
steve6367
« Reply #5 on: 17 February 2017, 10:51:48 »
Steve
There is a cabin temperature sensor also.
« Reply #6 on: 17 February 2017, 12:39:11 »
And almost every duct has a temp sensor in as well.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #7 on: 17 February 2017, 18:51:56 »
i put a stick on thermometer in my cabin.  the cabin temperature is almost never  the same as the cc set temperature - it can be higher or lower even after a long journey.  my conclusion is that the temperature set on the cc bears very little relation to the cabin temperature, the cc seems to set the temperature of the air through the vents rather than that inside the cabin.
« Reply #8 on: 17 February 2017, 19:35:23 »
That makes sense...
Given that its temperature sensors are in the vents ::)
Boatboy
  • St Albans
« Reply #9 on: 17 February 2017, 20:35:55 »
About face.. I've gone from no feedback to cabin sensor (where that then) and duct sensors.. :D
So I might find something to clean the dust off.
Steve
omega2018
« Reply #10 on: 17 February 2017, 21:48:25 »
That makes sense...
not really 'climate control' more 'wind control' then...
« Reply #11 on: 17 February 2017, 23:03:48 »
Wind being a climatic side effect...
omega2018
« Reply #12 on: 18 February 2017, 03:23:00 »
wind being what comes out of you ;D
steve6367
« Reply #13 on: 18 February 2017, 08:12:24 »
Steve
If you have diagnostic available plug in and you can view all the temps in realtime and see if anything is amiss  :y
