Author Topic: opps oppsety opps opps  (Read 6924 times)
« on: 16 February 2017, 16:38:00 »
Warning note to E39ists...
The front lower arm bolts through an insert. Brute force and heat produced this result...
http://share.photobucket.com/shareprofile/indexshare.php?id=NTcxMTY=
Assuming that I can successfully liberate the insert, I suspect that it's not designed to be removed from the hub carrier and should therefore be binned rather than refitted... Thoughts :-\
Re: opps oppsety opps opps
« Reply #1 on: 16 February 2017, 16:43:27 »
More worryingly, I discovered this notch caused by the arch liner rubbing... :o
http://share.photobucket.com/shareprofile/indexshare.php?id=NTcxMTg=
Which is why I started on this side rather than the one that was actually worn... ::)
« Reply #2 on: 16 February 2017, 17:07:05 »
Yes, that doesn't look good, on both counts.  :-\
Omegas are quite good, you know. You should try one... ;)
« Reply #3 on: 16 February 2017, 17:10:19 »
 :P
« Reply #4 on: 16 February 2017, 17:20:58 »
Is it a cast ali knuckle, then? Guessing so, if it needs an insert.
I wonder if putting the knuckle in the oven, insert in the freezer, smear of threadlock on it and knock it back in will work? :y
If you can get the ball joint separated from it, of course.
Worth putting a big washer on the back just in case the answer's no....
« Reply #5 on: 16 February 2017, 17:25:02 »
Balljoint now Donald and insert still very much welded to the shaft. Refitting the old arm is a lottery that I won't be buying a ticket for.
« Reply #6 on: 16 February 2017, 17:44:20 »
That said, the insert if fitted from above with the nut and washer underneath... Would keep it mobile until new hub carrier arrives :-\
« Reply #7 on: 16 February 2017, 18:13:10 »
Linkys no workys...  :(
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 16 February 2017, 18:18:21 »
This is one reason why the two hammer method of breaking baljoints should be used whenever possible. You need to shock tapers apart rather than force them
« Reply #9 on: 16 February 2017, 18:32:59 »
That didn't work  :'( not helped by it being in the middle of the carrier casting...
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #10 on: 16 February 2017, 18:57:25 »
How on earth have u managed that taxi? I did lower arms on a 5 series last week and the balljoints just popped out
RIP Paul Lovejoy
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #11 on: 16 February 2017, 19:16:18 »
Not saying you're wrong... as you're older and wiser than I.. but I've never had any luck with impact removal of tapers. I always have to use the ball joint splitter type devices  :(  Or "drift" the clamp apart.
Omegatitis : [in remission]
X30XE
  • UK
« Reply #12 on: 16 February 2017, 19:16:38 »
Turn off adblock on this page only ;)
X30XE
  • UK
« Reply #13 on: 16 February 2017, 19:17:24 »
Shhhhhut the front door! I hope that's an orginal arm to have worn that far in!  :o
X30XE
  • UK
« Reply #14 on: 16 February 2017, 19:18:04 »
Did you OIL it first? ;) ;) Ain't karma a bitch  :D
