Pages: 1 2 3 4 [5]  All   Go Down
Author Topic: Project MV6  (Read 27488 times)
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #60 on: 23 March 2017, 22:39:02 »
Last weekend I cut the overheating crimped terminal off the alternator/battery cable and managed to solder it back on. Charging and starting are much better now :y
I was hoping (am hoping?) that sorting the charging out would magically improve the fuel consumption so I have been checking the live data.
The first thing that cropped up was an 0420 code. After I had cleared it I realised that I hadn't noticed a warning light. Does the ECU in the 3.2 store pre-codes? :-\
Today I checked the live data again - no codes - but I noticed that the throttle position never goes below 5%. As a comparison I also checked my 2.6 and that does go down to 0%.
Ignore the battery voltages - I didn't start either engine, the 3.2 is still recovering since I fixed the battery terminal and the self levelling air compressor was running on the 2.6
« Last Edit: 23 March 2017, 22:45:52 by Andy H »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Project MV6
« Reply #61 on: 23 March 2017, 22:41:21 »
Possible that someone previous has adjusted base throttle settings to mask another problem which is why the throttle pot won't zero
other rides
Re: Project MV6
« Reply #62 on: 23 March 2017, 22:45:43 »
Could always swap the throttle bodies to test the theory ;)
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #63 on: 23 March 2017, 22:49:39 »
Feeling a bit silly now - squinting at the screen on my phone I hadn't noticed that I had mixed up the pedal position and the throttle position
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #64 on: 23 March 2017, 22:52:42 »
I think I will need to start with a breather and throttle body clean.........
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #65 on: 23 March 2017, 23:00:41 »
I suspect you might be on to something there.
When SWMBO bought a Golf a few years ago we couldn't work out why the idle was so fast. After some simple fault finding I discovered a faulty coolant temperature sensor. I changed that (and starting improved) but the idle was still far too fast. I eventually stripped the throttle body and found a piece of wood glued inside the gearbox to hold the throttle open....
I will give it a clean first to see if crud is holding it open.
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #66 on: 23 March 2017, 23:04:04 »
I could..... but the Elite has been good as gold and I don't want to disable it by robbing parts off it.
Re: Project MV6
« Reply #67 on: 23 March 2017, 23:20:16 »
Might make the MV6 better too... #glass half full ;)
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #68 on: 09 May 2017, 19:53:12 »
Having driven the 3.2 MV6 to work a couple of days a week for the last few weeks the average fuel consumption is reading 21mpg. On the same journey my 2.6 averages 26mpg. I can't really say that the 3.2 feels that much more powerful than the 2.6 but it is definitely noisier and less refined ::)
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #69 on: 24 November 2017, 22:18:11 »
New MOT issued for the project MV6 today :y
A few advisories for rust on brake pipes, front wishbone bushes and rear donut bushes.
I really need to make time to give this car some TLC....
gstylebaby
  • stockport
Re: Project MV6
« Reply #70 on: 01 December 2017, 04:39:24 »
Just took a couple of pics of mine.
Load cover in situ
Load cover removed but held in retainer.
Load cover locking tab for easy removal. The red tab was on the earlier load cover, not on the facelift, my mistake.
Pretty sure i have a pair of these still in the side trims i stripped out of mv6. What year is yours these came out of a 1998 t plate and look the same shape as the photo ones. I never got round to listing them lol like other parts of the estate and now im stripping my saloon which is killing me but gotta do what you gotta do.
  • Auckland
    • Mazda MPV
Re: Project MV6
« Reply #71 on: 01 December 2017, 08:32:12 »
Thanks for the offer but I got some from another member on here. :y
Pages: 1 2 3 4 [5]  All   Go Up
