Author Topic: No throttle after throttle body and breather clean  (Read 8705 times)
Butts69
  • Christchurch
    • 2.2 sport
Re: No throttle after throttle body and breather clean
« Reply #15 on: 20 February 2017, 12:17:18 »
Sorry meant to say second hand throttle body.
Butts.
Butts69
  • Christchurch
    • 2.2 sport
« Reply #16 on: 20 February 2017, 15:30:08 »
Update. left car for 3 hours, started with foot planted on accelerator, fired straight up with throttle working but engine running like a three legged donkey, idle all over the show ran like this for a couple of mins, tried cutting out a few times then did. started straight up again same problem, cut out again. restarted again and engine running smoothly but lost throttle. so I either have a smooth engine with no throttle or a bag of bones with throttle. ???
Cheers Butts.
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« Reply #17 on: 21 February 2017, 05:53:29 »
Have you already checked what codes it gives? And tried to clear them after checking?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #18 on: 21 February 2017, 08:30:42 »
Sounds dim - plug on the right way round?
Butts69
  • Christchurch
    • 2.2 sport
« Reply #19 on: 21 February 2017, 11:22:10 »
Hi thanks for replies, yes plug is on correct way round grey clip at top. sorry don't have code reader have one on order but won't be here until next week and I've got to go to Wigan on a training course from Sunday so I might have go by train if I don't get this fixed.
Car had been running ok until I cleaned out breathe system.
Butts
Butts69
  • Christchurch
    • 2.2 sport
« Reply #20 on: 21 February 2017, 12:16:23 »
Hi all. Just started her again and I had full throttle control but idle was all over the place, ran her with keeping revs ups until up to temp and then idle sat at 6-7000 revs. switched her off and started again No throttle again but idled smoothly at 12000. started another couple times and got throttle control back. switched off and started again no throttle. it seems every 3-4 starts I get throttle control, but other times I don't. But this is a lot better than yesterday, it's like she is getting used to breathing again. any thoughts on this problem will be much appreciated.
Cheers Butts.
« Reply #21 on: 21 February 2017, 12:37:33 »
Check all the pipes are connected properly, it sounds like an air leak to me.
Butts69
  • Christchurch
    • 2.2 sport
« Reply #22 on: 21 February 2017, 14:16:28 »
Checked all pipes and checked again and checked for splits, all seem ok, that was what I was thinking. but could it be because it was so blocked before no air was getting through system and now it is it does not like it. Seems to get a bit better each time I start the car. It was running ok before the clean just had a lumpy throttle.
Cheers Butts.
Butts69
  • Christchurch
    • 2.2 sport
« Reply #23 on: 21 February 2017, 14:50:56 »
Another update. just started it a few times and all seemed ok went for a 10 min drive all ok. Got home switched off and started again no throttle control again.  ???
Butts
Butts69
  • Christchurch
    • 2.2 sport
« Reply #24 on: 22 February 2017, 21:17:36 »
Hi all, Think I've sorted it. Got second hand throttle body off flebay for £25, fitted it everything has worked fine since. must have got cleaning fluid in the electronics off the old throttle body  :-[. So hopefully she will get me to Wigan and back next week. Cheers for the help.
Butts.
ps anybody want a throttle body change I've got it down to 12 mins  ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #25 on: 22 February 2017, 21:24:47 »
Going by the rest of the thread, I'm not sure you can be trusted ;)
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #26 on: 22 February 2017, 22:40:03 »
Bwaa!!  Tea everywhere!  ;D
Omegatitis : [in remission]
Butts69
  • Christchurch
    • 2.2 sport
« Reply #27 on: 22 February 2017, 22:47:53 »
That's it pick on the new kid. ;D
X30XE
  • UK
« Reply #28 on: 22 February 2017, 22:51:13 »
You live and learn. And at least you fixed it yourself  :)
