Carb Cleaner
Started by X30XE, 19 February 2017, 19:00:56
The later crank based oil pumps should self prime so check the pickup is on properly.  It's also possible to use an oil can and feed oil I'm through one of the rocker shaft oil feed holes to get the upper galleries filled
X30XE
Quote from: Marks DTM Calib on 27 February 2017, 18:46:50
Put the pickup back on myself so I'm happy with that.  Are the rocker shaft oil feed holes supposed to point downwards?
Omegatitis : [in remission]
X30XE
Got it fired up earlier, nearly literally when it transpired no4 injector o ring wasn't sealed to the fuel rail and started pissing petrol out  :o
Not looking good for oil flow to the heads though :(
