Author Topic: Knocking n/s/f  (Read 13793 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Knocking n/s/f
« on: 19 February 2017, 20:47:11 »
Quite a severe knocking when going over bumps and even when applying the brakes, from the n/s/f. I fitted new Meyle droplinks today but that hasn't cured it.
I observed there was noticeable play in the wheel bearing, question is, would that be a likely cause of these symptoms. I cant see it myself, but I may be wrong.  :-\
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
Re: Knocking n/s/f
« Reply #1 on: 20 February 2017, 08:25:20 »
Following as iv same but only when turn or a little bump
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Migv6 le Frog Fan
Re: Knocking n/s/f
« Reply #2 on: 20 February 2017, 09:44:43 »
The usual cause is droplinks needing replacing which is why I did that first. In my case it hasn't worked though.
I shall probably replace the wheel bearing (hub) soon anyway, and if it isn't that, then dampers and top mounts are about the only thing left to change.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Knocking n/s/f
« Reply #3 on: 20 February 2017, 10:13:53 »
You can determine if it's the wheel bearing by jacking the car and inspecting. It's unlikely to be the problem,as you would have other symptoms. Changing them just for the sake of it is daft.
Which leaves a worn out shock/top mount/bearing/rusty strut tower.
Knackered shock is where I would look next.
Elite_L0ver
  • On too Omega #2
Re: Knocking n/s/f
« Reply #4 on: 20 February 2017, 11:47:49 »
If it was WB then you would hear a grumbleing noise would you not
Migv6 le Frog Fan
Re: Knocking n/s/f
« Reply #5 on: 20 February 2017, 12:33:23 »
Definitely noticeable bearing play when pulling / pushing on top & bottom of the disc.  :y
I'm also suspecting shock. Being an elite,means its quite "floaty" anyway, so maybe not as easy to diagnose as an MV6 say.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Knocking n/s/f
« Reply #6 on: 20 February 2017, 13:54:26 »
Play at 12 and 6 isn't always a bearing. If you do that and feel the top mount I bet you'll find it's that that's causing the knocking and the play. Check the nuts tight and if it is replace top mount
RIP Paul Lovejoy
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Knocking n/s/f
« Reply #7 on: 20 February 2017, 14:50:05 »
Check the rear vertical bush on the suspension arm.this can detach itself from its rubber surround
Migv6 le Frog Fan
Re: Knocking n/s/f
« Reply #8 on: 20 February 2017, 17:45:49 »
Its almost brand new, genuine GM. ;)
cam.in.head
  • West yorkshire
Re: Knocking n/s/f
« Reply #9 on: 20 February 2017, 18:42:36 »
Worth a wiggle but we can probably eliminate that then !
Migv6 le Frog Fan
Re: Knocking n/s/f
« Reply #10 on: 01 March 2017, 11:31:20 »
Removed the strut this morning to see if there was anything visbly obvious, which there wasn't. Problem is I don't have any spring compressors to strip it any further, so cant ascertain if the top mount bearing is knackered or not.  :-[
Should be able to borrow some compressors soon, so can hopefully carry on with diagnosis shortly.
Elite_L0ver
  • On too Omega #2
Re: Knocking n/s/f
« Reply #11 on: 01 March 2017, 13:09:40 »
Iv a pair u can borrow :y
Migv6 le Frog Fan
Re: Knocking n/s/f
« Reply #12 on: 01 March 2017, 13:37:43 »
Very kind offer thanks, but Ive arranged to borrow some from a workmate.  :y
Elite_L0ver
  • On too Omega #2
Re: Knocking n/s/f
« Reply #13 on: 01 March 2017, 15:30:46 »
Ok buddy be interested to know what the outcome is as my steering is a little wavey n I've a knocking coming from ns also
Re: Knocking n/s/f
« Reply #14 on: 01 March 2017, 15:45:24 »
99/100 droplinks knocking and worn bushes... bet yours is between 80 and 120k miles old ;)
Pages: [1] 2 3 4  All   Go Up
