Author Topic: Mot Day and It Passed Just !!!!!!  (Read 4108 times)
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« on: 20 February 2017, 19:03:24 »
Well as per title it was mot day it passed but only just due to emissions  :'(
The Easy advisories
1) Wipers Smear (easy)
2) Stonechip in windscreen (easy)
3) Exhaust has minor leak of gasses
Ones im not so pleased with need to sort out any help welcome
4) Rear Subframe Bushes Worn
5) Offside Front To rear brake pipe corroded
6) Both Rear inner Sills corroded
7) N/S Front inner wing corroded.
Have i brought a duff what can i do
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Re: Mot Day and It Passed Just !!!!!!
« Reply #1 on: 21 February 2017, 07:59:04 »
Last four are standard Omega items...  ;)
106pete
  • Plymouth
    • Omega 3.0 elite
« Reply #2 on: 21 February 2017, 08:12:53 »
Mot guys like to just advise anything that has a hint of rust and any bush that looks used just to cover themselves these days.
« Reply #3 on: 21 February 2017, 09:41:28 »
Rear donut bushes are available off the shelf, either GM or poly (Pedders sell them, IIRC) and poly are a relatively easy DIY.  If they mean the diff bushes though, those are no longer available so need remanufacturing (Nick W has a post on that) or good secondhand (hard to find), still easy enough to fit though.
Wire brush it, make sure it doesn't look like a dogs c.. dangly, grease/paint and forget.  If it looks too far gone then replacement is the only option and if you're not competent you'll want to pay someone like serek to do it.
Get the screwdriver out and start poking, if any holes appear, find a good welder.  If not, grind back, paint, and forget (unless you intend to keep the car a number of years and then get it welded instead)
Elite_L0ver
  • On too Omega #2
« Reply #4 on: 21 February 2017, 10:22:17 »
Yes i plan on keeping the car for as long as it keeps running so want to crack down on any issues as it will be a daily driver also.
So out with the wire brush it is then
The bushes i will call and confirm today but i think they ment the dounut not diff bushes
The mot guy is not one to point out just anything as iv been using them for years and been happy with the service/standard  :y  :y :y
« Reply #5 on: 21 February 2017, 11:43:23 »
Gollum has a post somewhere with good pictures of an inner arch treatment with wire brush & paint, worth searching that out  :y
Elite_L0ver
  • On too Omega #2
« Reply #6 on: 21 February 2017, 18:43:51 »
Anyone got the link cannot seem to find it  :-\
« Reply #7 on: 21 February 2017, 23:13:51 »
Picture is long since toast, but will try and dig it out ;)
Elite_L0ver
  • On too Omega #2
« Reply #8 on: 21 February 2017, 23:33:42 »
Thanks :y
« Reply #9 on: 22 February 2017, 10:30:47 »
http://www.omegaowners.com/forum/index.php?topic=43963.13605
post no 13607 ...  ???
Elite_L0ver
  • On too Omega #2
« Reply #10 on: 22 February 2017, 10:34:47 »
« Reply #11 on: 22 February 2017, 13:33:09 »
Zirfeld
  • Lahr/Germany
    • 2.0/16V Saloon+Estate
« Reply #12 on: 22 February 2017, 16:19:48 »
Hi
Most of the problems (and some more  :-[ ) I had last year with my 98 saloon.
I have a little blog in a German forum and I described in detail what I did. You can use google translator or me ask here. There are dozens of pictures in detail. You will find solutions there.
http://www.modern-classics-forum.de/board5-youngtimer-technik/board6-karosserie/2092-rettung-eines-omega-b/
Rolf
I am not forced to drive an old Omega. I simply like it.
