Author Topic: 2.2 Locking tool freek find  (Read 11449 times)
Viral_Jim
  • Telford
    • Too many, mostly broken
Re: 2.2 Locking tool freek find
« Reply #15 on: 24 February 2017, 00:34:06 »
Go for it  :y
The joy of the desmond is that there is so much space to work and its fundamentally a really simple engine. I did mine in 2.5hrs or thereabouts and was reliably informed that I was slow as f@ck.  ;D
Last one I did was on a transverse 2.5 v6 AWD X-type. I concluded that what I really needed was a left handed proctologist to help me out with that one!  ;D
Does your kit include a water pump? if not I'd get one "while you're in there" as they are cheap as chips and its a good excuse to drain & change the coolant.
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« Reply #16 on: 24 February 2017, 05:29:39 »
Here's what I used as locking tool  :y
« Reply #17 on: 24 February 2017, 07:08:12 »
Waterpump is essential on the 2.2 as it's what tensions the belt :y
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« Reply #18 on: 24 February 2017, 07:39:29 »
Really  :D :D ;) :D :D
It Has been ordered aswell and will be replaced
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
Elite_L0ver
  • On too Omega #2
« Reply #19 on: 24 February 2017, 08:44:59 »
Well iv found an answer to this one and the answer is yes it is the 2.2 locking tool and heres proof
I think the Blue is for the 1.6/1.8 small blocks and the Gold for the 1.8/2.0/2.2 big block engines
So im ready to go when parts arrive Thanks for your help guys i may do a picture guide for Guide also
« Last Edit: 24 February 2017, 08:53:18 by Elite_L0ver »
Viral_Jim
  • Telford
« Reply #20 on: 24 February 2017, 09:54:01 »
Well there you go, I must have completely mis-remembered how the timing belt goes on, thought there was a separate tensioner.  :-\
Going senile in my 30's - not a good sign
mandula
  • Finland
« Reply #21 on: 24 February 2017, 10:37:45 »
Yep, it was purrrfect  8)
Of course it was adjusted just as tight that it could hold wheels still, not to bend them out of shape  ::)
mandula
  • Finland
« Reply #22 on: 24 February 2017, 10:40:39 »
Umm.. There sure is a tensioner.. At least I have.
Elite_L0ver
  • On too Omega #2
« Reply #23 on: 24 February 2017, 10:46:35 »
Fair one if they work then fair play at least iv a back up plan if all else fails :y
« Reply #24 on: 24 February 2017, 11:11:20 »
Mole grips are illadvised as they can break the pulleys...
mandula
  • Finland
« Reply #25 on: 24 February 2017, 11:14:40 »
Usage of the common sense is crucial when using advanced methods like that  ;)
For me, there were not even a scratch on pulleys surface when I removed those grips. But I sure understand that if someone with too much power and too little sense uses that method, will sure deform or even crack the pulleys. In that case, it would be best just to focus only to oil change operations and leave all the rest to mechanician  ::)
« Reply #26 on: 24 February 2017, 12:08:37 »
They're relatively brittle by virtue of how they're made :)
