Author Topic: Engine light came on....  (Read 4971 times)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« on: 23 February 2017, 16:53:40 »
I am on a short break in Swanage for stress relief and on my way back from Weymouth this afternoon the engine symbol on the display came on, but there were no other signs of abnormality - it drove perfectly normally and temperature display, etc., were as per normal.
Back at Swanage, I hoped that switchingn off and back on again would put the light out, but no such luck.
Should I ignore it, or does it indicate am problem and Green Flag will have to take me back home?
Thanks,
Ron.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Engine light came on....
« Reply #1 on: 23 February 2017, 16:57:39 »
Peddle Trick it, whats the Code(s)
Bigron
  • Witham, Essex
« Reply #2 on: 23 February 2017, 17:04:16 »
Thanks, Zirk, I've heard of the "pedal trick" but don't know what it is or how to do it - explain, please?
Ron.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #3 on: 23 February 2017, 17:07:35 »
When mine came on, i presume you mean the Engine block light not spanner light, the light used to go off the next day. But, mine is only a humble desmond :) Hope it,s nothing serious mate. :y
« Reply #4 on: 23 February 2017, 17:08:29 »
Check the guides for the pedal trick.
My money is on the precat codes ;)
zirk
  • Epping Forest
« Reply #5 on: 23 February 2017, 17:10:23 »
Ing. off. Brake and Throttle pedal fully down, Ing back on, the EML will flash 1 to 10 times each (10 being zero) write the codes down and look up the Code, its all in the Guide Ron, have a read as need to walk out of the door in a min or two.
Bigron
  • Witham, Essex
« Reply #6 on: 23 February 2017, 17:39:45 »
Well, it looks like 0; 4; 3; 0 and all I can find in the Help files is 0;3;4;0 = camshaft sensor.
I could be wrong!
Ron.
« Reply #7 on: 23 February 2017, 17:44:13 »
I could be wrong!
Ron.
Cat Efficiency code... Nothing to worry about for now :y
« Last Edit: 23 February 2017, 17:46:35 by Lazydocker »
Bigron
  • Witham, Essex
« Reply #8 on: 23 February 2017, 17:46:46 »
Phew, LD - I could kiss you! :-*.......not really, but you know what I mean!  :y 8)
Ron.
« Reply #9 on: 23 February 2017, 17:47:58 »
Drive it a bit harder and it'll probably go out again :-X ::)
Bigron
  • Witham, Essex
« Reply #10 on: 23 February 2017, 17:52:27 »
I think I'll treat it to a dose of "Cataclean" - it helps with the MOT, so maybe.....
Thanks gents, another OOF rescue!  :y
Ron.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #11 on: 23 February 2017, 17:55:28 »
Ive taken the bulb out of mine. Will clear the code and put the bulb back in at MOT time.  ;)
Bigron
  • Witham, Essex
« Reply #12 on: 23 February 2017, 18:00:28 »
"Mig", that's the best larf I've had in a long time - are you related to Arfer Daley?    ;D 8)
Ron.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #13 on: 23 February 2017, 18:38:53 »
I know a bloke[not an Omega owner]who stuck a piece of insulating tape on the dash clocks to "cancel out"the warning light :o
Migv6 le Frog Fan
« Reply #14 on: 23 February 2017, 19:59:11 »
Ron.
Nah, but I'm related to Arfur lager.  :D
Thing is, the only proper cure is to move the Lamdas, and I'm not currently planning to do that. I can clear the code and put the light out, but it comes back the next day. Possibly due to the fact that I am now a pretty slow driver.
Get p1ssed off looking at the orange light, so just removed the bulb. Only takes 5 minutes to whip it out and put it back so it seemed sensible to me.  :)
Btw Ron. Is your car the dark grey Omega which is usually parked in Sauls Ave, (think ive got the right road) ?
