Pages: 1 2 [3] 4 5 6 7   Go Down
Author Topic: Iv fooked it i think  (Read 34447 times)
Re: Iv fooked it i think
« Reply #30 on: 25 February 2017, 10:45:45 »
Done more of these cambelts and top end v6 rebuilds than I care to remember - I will gladly take a trip over for the cost of fuel and a small contribution to my "fix the beemer" fund :y
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« Reply #31 on: 25 February 2017, 16:26:36 »
JamesV6CDX I very much appreciate it it is now running after a mate of mine come over and give me a hand it was 180* out timing wise so started from scratch and although its running the best way i can discribe is it sounds like a diesel with the belt vibrating on top between the cams but is taught everywhere else  any ideas
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #32 on: 25 February 2017, 17:01:25 »
Belt a tooth off at the top, remove it, position and retension it correctly.
Elite_L0ver
  • On too Omega #2
« Reply #33 on: 25 February 2017, 17:20:05 »
Both marks lined up though is it ok to run
Elite_L0ver
  • On too Omega #2
« Reply #34 on: 25 February 2017, 18:16:21 »
This were the marks after we turned it by hand
« Reply #35 on: 25 February 2017, 18:53:59 »
Without seeing it, id suggest rotating each cam half a tooth so you get one less belt tooth in between them, before you tension it.
Clear as mud, I fear
  • Auckland
    • Mazda MPV
« Reply #36 on: 25 February 2017, 18:55:14 »
Is there a piece of crap stuck between the teeth in one of the cam pulleys?
Is the spring tensioner set correctly? I can't see the spring tensioner clearly enough to tell in your photo.
Elite_L0ver
  • On too Omega #2
« Reply #37 on: 25 February 2017, 19:12:03 »
Did not see anything i dont think there was
I followed autodata to a t to tension belt! It only pulls back when at low speeds or pedal released
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #38 on: 25 February 2017, 19:33:14 »
Should be impossible surely  :-\  Bit like saying the tyre is only flat at the bottom...  So unless the valves are clipping the piston... ?  ???
Omegatitis : [in remission]
« Reply #39 on: 25 February 2017, 19:50:51 »
Long and the short, it isn't timed properly. Does the cam lock fit in the cams when the crank is set correctly?
Elite_L0ver
  • On too Omega #2
« Reply #40 on: 25 February 2017, 20:17:50 »
We are in talks now guys and looks like JamesV6CDX will be over to help sort it tuesday TO WORK HIS MAGIC
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #41 on: 25 February 2017, 21:42:29 »
You will never regret it - James is ACE! How do I know? He did mine and his attention to detail is beyond reproach; he's a great bloke, too.
James, if you happen to read this, TAKE IT EASY!  :y
Ron.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #42 on: 25 February 2017, 21:53:37 »
Yeah, looking at that picture, the left cam looks like the mark is in line with the timing mark on the block, but it shouldn't, because the camera is not bang in front of the cam. I would say that the cam should be half a tooth anti clockwise.
This would also explain the slop in the belt between the cams. My guess is the tensioner isn't set correctly to pull the slop out.
Glad you have James coming over. By all accounts he's a mechanical whizz and a top guy to boot.
Elite_L0ver
  • On too Omega #2
« Reply #43 on: 25 February 2017, 22:18:56 »
Ron.
Thank you guys i dont think i have made a bad decision (apart from rushing to do it myself) it is being left for James magic hands  🙌🤞👍
X30XE
  • UK
« Reply #44 on: 25 February 2017, 22:46:40 »
Makes no sense to me squire... the belt pulls the sprockets round not t'other way round. If the belt ain't moderately tight it don't pull the sprocket.  ???
Pages: 1 2 [3] 4 5 6 7   Go Up
Page created in 0.03 seconds with 20 queries.
